Misfire Cylinder 1?
Old Aug 16, 2010 | 12:00 PM
Tubzzz14's Avatar
Misfire Cylinder 1?
Hey my evo x has been idling rough and i brought it in to get my codes read adn they guy said it was a misfire on cylinder 1, what should i look for?
-fouled spark plugs
-cracked spark plugs?
What else could cause this
Old Aug 16, 2010 | 05:22 PM
dreamerak's Avatar
-fouled spark plugs
yes and yes + everything in the entire ignition system. sometimes you can have a bad plug with no visable defects. make sure everything is properly grounded too.
Old Aug 16, 2010 | 05:30 PM
overboostin's Avatar
whats done to the car?
Old Aug 16, 2010 | 07:54 PM
lousEVOxmr's Avatar
happend to me once change the plugs
Old Aug 17, 2010 | 06:31 PM
RB185AFM's Avatar
I had a misfire on cylinder #3 with my stock plugs on my below set up. Put in the colder heat range HKS's and no more misfire. When I pulled my stock plugs they all looked good but apparently something was not working on one plug.
Old Aug 17, 2010 | 07:07 PM
murlo26's Avatar
Last misfire code i had was the random misfire....and then a few hours later...my motor exploded
NO worries, i am sure you are fine
Old Aug 17, 2010 | 07:14 PM
RB185AFM's Avatar
LOL way to ease the mind. After my misfires, as I had many, I did a compression leak down test to make sure my motor was still healthy. Luckily it was.
Old Aug 17, 2010 | 07:16 PM
murlo26's Avatar
I try
First code i ever had and the last one...i just had to rip that stupid POS IROC camaro a new a hole...he was giving me crap at the stop light...then he said his carb was messed up the first time so I two stepped it the next time to really rip him one, lol. Was fun, but costly.
dbltz
Oct 6, 2014 03:51 PM
evo4sho
Sep 10, 2010 12:07 PM
DDTPro17
Jun 24, 2008 09:16 PM
DDTPro17
May 23, 2008 02:40 PM
cableguy5752
Mar 16, 2008 08:55 AM
