Are all EBCS created equal?
Old May 6, 2022 | 07:36 PM
pumpkinpot's Avatar
Hi all,
Does anyone know if all EBCS are created equal? (in other words, it either works or it doesn't)
Old May 7, 2022 | 03:03 AM
Lightsaber's Avatar
AFAIK there are only two 3-port boost controllers available for our Evo X: Grimmspeed 3-port boost controller (p/n 057033) and Cobb 3-port boost controller (p/n 752750). I heard that the solenoid itself is made by the same manufacturer, so, theoretically, as long as they are new and working, they should deliver the same results.
However, from Evo X owners and professional tuners, I've heard complains that the Grimmspeed boost controller has flimsy vacuum hose fittings. Some EvoScan tuners even have a preference for the Cobb boost controller because of its better-quality fittings. If you want to keep your car for the long term, then the Cobb boost controller may be worth the extra.
By the way, tuning the Evo may change the CVN (calibration verification number) which will prevent you from passing the California state inspection.
MatcoBill
Jul 10, 2011 09:57 AM
veilside prius
Jan 21, 2008 08:10 PM
