Evo x vacuume lines mixed up?
Old Oct 16, 2022 | 12:52 PM
Assassin11z7's Avatar
Hello all,
I have a few questions about some of my vacuume lines on my 2015 evo fe. I bought the car almost 2 years ago and have had issues with it since. Right now I'm throwing a lean code that I think was my maf. I cleaned it and the intake up and the code went away(catch can ordered and otw). I have the 3 port grimmspeed boost controller. I watched how to run those on YouTube but the solenoid that has the black plug on it under the 3 port has a nipple with nothing connected. I know the brown plug solenoid was removed for the 3 port but does the black plug one go somewhere? Number 2 is the hose coming from the bpv is supposed to go into the front of the motor coming from the hardline has a tee splitting it and going back behind the boost controller that looks like a 1 port solenoid with a cable coming out of it. Is this supposed to be teed off here? All my 3 port hoses are directly to wg, turbo inlet and ets intake.
List of all mods that i know of(understand some are irrelevant but it's easier to copy and paste than to write it out)
Bride Lowmaxx Racing seat Evasive motorsports Seat rail Ohlin R/T coilovers ETS V2 Extreme Turboback exhaust with HFC ACT 6 puck clutch Fidanza pro-lite flywheel Advan RSDF Forged 18X10.5 +24 offset Michelin Pilot 4S 285/35R18 (all 4) Hawk HP + pads with Brembo brakes Grimmspeed Electronic boost controller (3 way) BOSCH Injector Dynamics 1300 CC injectors Fully Custom Carbon Fiber Weel from NRW (NELSON RACING WHEELS) 2 POD pillar for Guages Innovative motorsports EFC-1 Guage, ALL in one- ETHANOL guage, A/F, FUEL pressure and fuel temp Innovative Motorsports Boost Guage with shift light Extreme Turbo Systems (ETS) Intake with MAF Walbro 450 fuel pump. Hella supertone horns Torque solutions short throw Torque solutions shifter bushings and linkage bushings Transmission refresh at 40100 miles w/o final drive. (4th and 5th gear,
Hose coming from bpv
This is the solenoid or whatever that the bpv tees off to
Farther pocture for reference
Nipple from black plug solenoid that is open
Another angle of the line
synchros, sleeves, seals, gaskets, o-rings, double roll pin conversion w/ safety wire)
Old Oct 18, 2022 | 01:42 PM
bcollins92's Avatar
That little black box t'd into your BPV is for your boost gauge. The solenoid below your 3 port is fine its supposed to be left just like that.
Old Oct 22, 2022 | 08:57 AM
OK hell yeah. My gauge is reading an e2 code on the afr portion of it. Online it says either a faulty sensor or bad connection so I wasn't sure if those vacuume hoses had something to do with me not getting my afr readings. It makes me feel better that that port is supposed to be left open lol. thank you for your input!
nglett
Jun 3, 2021 08:10 AM
Assassin11z7
Jan 18, 2021 08:34 PM
boos929
Northeast Region
12
Oct 5, 2013 02:48 PM
MR Turco
Aug 29, 2008 05:56 AM
