Dyno tune
Old Jan 2, 2023 | 08:47 PM
cxshsky's Avatar
will my evo need a tune?
so i blew my old engine and i had it tuned by english racing and i got a new motor swap didn’t change any of the bolts on they stayed the same do i need to get a new tune or will i be fine with my old tune ?
PLEASE HELP ASAP
Old Jan 4, 2023 | 06:22 AM
splattj's Avatar
Do you know why it blew? If it was too aggressive a tune, you'll want a new tune.
Old Jan 4, 2023 | 07:12 AM
TimInselman's Avatar
No 2 engines will run exactly the same even if they are built to same spec. the tune could be safe enough that it's ok but why risk it? Re-tunes are usually half the cost of a full tune as well so should only be a couple hundred bucks for the piece of mind knowing the tune is good.
Old Jan 4, 2023 | 04:31 PM
Pal215's Avatar
If you are using the same parts, chances are you are good to drive on it as long as you stay out of boost. You aren't using the same oil cooler correct?
When you get into boost is when you will start to see differences and will need a retune. English Racing tunes are rather solid so I would think that the engine failed due to other factors.
Old Jan 4, 2023 | 06:01 PM
cxshsky's Avatar
the engine blew cause we were messing with the cobb access port and switched to a stage 1 cobb tune and did a pull and blew the engine it was my fault
Old Jan 4, 2023 | 06:02 PM
cxshsky's Avatar
yes i do it blew cause i switched to stage 1 cobb tune on accident and blew it
Old Jan 4, 2023 | 06:03 PM
cxshsky's Avatar
it failed due to switching to a stage 1 cobb tune and i called english racing and they said id be fine and good to go thank you
cumminsracer14
Dec 2, 2016 02:53 AM
Tommy_Lee
12
Jul 28, 2010 09:16 AM
younggindamix
North Texas Evo Club (NTEC)
Jun 10, 2010 08:32 AM
CA$H
Northwest Region
Sep 27, 2008 05:20 PM
SlowCar
South Region
73
Apr 2, 2007 06:24 PM
