Part II: Evo X Tuned
shiv
I understand what you are using Shiv, Im just not a fan of the signal modification systems. I understand the complexities of the ECU's as well. I write this type of micro-code for a living. Im not being aggressive against the Proceed, I understand well what it does, but I am certain you can agree that the best ECU for a car is the stock ECU, unmodified. I am sure you, as I, have seen many times when these devices have inadvertently failed for some reason and caused a seriously undesirable side effect. Unfortunately I have seen these devices set a car on fire and blow the motor. Hence my hesitation to ever want to use one again. Im not willing to take the risk.
This is why I am more interested in the ECU tuning. I would like to have direct control over my ECU and manage my own tunes so that I know I am not getting screwed by some has been hack that thinks he knows how to tune cars. Believe me when I say I am not referring to you when I say this. I have always respected your talents, and I have always considered you to be one of the best car engineers out there.
So tell me, will you be offering such a device?
Shiv
PS. The first post has been udpated with a dyno graph
So the man just squeezed out 85 whp and 75 wtq with an exhaust and high flow cat but people are arguing about the downsides of highjacking ecu signals and what not????? Why dont all you guys go start your own thread and try not to clutter Shiv's thread. I want to see how much power he can squeeze out of this car without sifting through all of the foolishness.
Shiv, any possibility that you could overlay dyno runs with the mustang dyno the same way you do with the dynojet and Dyno Dynamics?
Agreed! Let Shiv post his results please....I can give a **** if it's a mouse on a wheel attached to the ECU if it obtains an additional 80whp I am down
Forgot to mention piggy back tune above. People are failing to realize that this is the first tuned Evo X in North America. And he only had the car for 2 weeks. WTF is the problem??? I cant understand trolls and their inability to let the past be the past. The Evo 1-9 is the past. Let this thread be about the current achievements for the current platform and future goals.
On a separate note ... how customizable will the Evo X PROcede be for the end user? Towards the end the XEDE was fairly programmable, which was nice, how are you guys as far as releasing that kind of info for the PROcede?
l8r)
Being on-topic and looking at the dyno graphs, the car seems like it has difficulty making power above 6500rpms. Both tunes show a pretty steady decline @6500rpms till he let off. Could this be the turbo?
Also, basically a 13whp increase over base tune (w/ stock exhaust) with the cat-back and hi-flo cat. I expected more actually.
Since the torque drops off @6500 in both dyno's, I'd inclined to think thats due to cam profiles. The stock turbo might be running a bit out of breath too. But just switching to 93 octane will probably add ~20whp without the turbo doing any more work.
Shiv
