AMS EVO X O2 Housing / Eliminator with Comparison Pics!
Old Dec 24, 2008 | 05:16 AM
  #196
Mojito's Avatar
Then, I guess, it's not really necessary.
Old Dec 24, 2008 | 07:43 AM
  #197
spdracerut's Avatar
Originally Posted by gunzo
Since it's cast, why didn't you guys make a flow separator ??
BECAUSE it is cast, it'd be difficult to cast in a separator. Plus, I'm not sure how much of a benefit it'd be for the reason that the flow out of the turbine wheel has its own flowpath of about 2-3" before it gets to the elbow anyways.
Old Dec 24, 2008 | 08:24 AM
  #198
lowkey's Avatar
Registered User
When WORKS came out with their cast O2 housing for the Evo 8/9, some folks believed it actually performed worse than the OEM unit. WORKS insisted it was better, but they also said you needed to increase the boost to make it perform up to potential. Not saying this is the case with the AMS one.
Old Dec 24, 2008 | 08:34 AM
  #199
spdracerut's Avatar
I think 'those folks' either didn't have a proper setup or just don't know what they're talking about. The main benefit of the Works was the actual 3" outlet of the elbow as opposed to the stock size of 2 3/8" IIRC. The stock might even be smaller.
If those folks used anything but a 3" inlet on the downpipe (76mm), then I could see how they would get worse performance as they'd go from a big hole into a small hole with a step change causing a flow resistance. Considering the number of 70mm, or 2.75" downpipes on the market, especially from the Japanese companies, it woud not surprise me if they created a bad mismatch of parts.
Old Dec 24, 2008 | 08:41 AM
  #200
lowkey's Avatar
Registered User
True. Just want to see the dyno result and I’m sold. This is a nice piece.
Old Dec 24, 2008 | 05:46 PM
  #201
gunzo's Avatar
Because its CAST, it's easier to make it in the mold stage ..
The benefit is ALOT MORE than without one .. it doesn't matter if it's smooth and contoured .. flow turbulence is flow turbulence .. the further downstream you separate the 2 flows, the better and faster the flow ..
Unless you have CFD software .. its probably difficult to visualise ..
Merry christmas guys ..
Old Dec 24, 2008 | 10:45 PM
  #202
spdracerut's Avatar
It would also be a more expensive casting though Pretty much every step for casting it would get more complicated; molds, core boxes, etc etc. Added material cost too.
In this particular case, the flow from the turbine wheel has a clean path straight out of the wheel with no distrubtion from the wastegate flow, for a good 2-3 inches.
If you were go separate the flows and merge them further down as is generally considered 'ideal', I'd estimate that the main part of the power gain is not from preventing turbulence between the wastegate flow and turbine wheel flow as I think you're suggesting.
With the stock elbow, the flow from the turbine wheel gets dumped into a large volume chamber. So you'll get a pressure drop as the flow slows down at the step change from small area to BIG area. And the fact it's a big step change as opposed to a nice diffuser means even greater pressure drop. Then, it has to accelerate back up to a higher speed because of the small area of the discharge from the elbow.
Well, that's my best estimation at least. Merry Xmas everyone!
Old Dec 25, 2008 | 12:42 PM
  #203
Robevo RS's Avatar
Originally Posted by AutoMotoSports
We are very close guys! Here is our first sample cast section welded to a flex pipe. Obviously this is not complete but the cast looks really good and will really help with reliability and heat transfer. Also you will notice the holes in the unit for a heat shield we will be incorporating with it
that is an awesome looking piece!
And finally aftermarket guys, making heat shield for they exhaust product.
Old Dec 25, 2008 | 04:52 PM
  #204
gunzo's Avatar
Actually .. with a cast .. once the mold is made .. its cheaper ..
The straight path flow is visual .. fluid flow is different
Actually for the last para, you got it wrong way round .. you WANT pressure drop ..the turbine spins primarily based on pressure differential .. the higher the differential the better your turbine spools .. what happens when you have turbulent exit is they become a bottleneck .. and the pressure increases at the exit end .. slowing down the turbine speed .. that is the reason for the elbow .. reduce turbulence, increased area and increase turbine response
My point on asking in case I miss it is .. if you want to do it ..then do it right
Maybe AMS found something different .. or its a compromise for a heatshield
Old Dec 25, 2008 | 05:04 PM
  #205
spdracerut's Avatar
Ah... you're correct. I guess I should've said that big step change causes a big flow resistance and the decreased flow velocity increases the static pressure behind the turbine wheel, which hurts response as you pointed out. 'Backpressure' right?
I blame it on the egg nog!
Old Dec 26, 2008 | 09:19 AM
  #206
AutoMotoSports's Avatar
Rich was kind enough to take some more pictures to give you guys a good idea of what this piece is like compared to stock. First is a picture of the turbine housing on the stock turbo to give you an idea of how it bolts up. Next are a couple of comparison pics
Lastly a very scientific comparison pic of how far I can shove my arm into each.
Old Dec 26, 2008 | 09:44 AM
  #207
HybridKOOP's Avatar
Eric... you have something on your arm...
Old Dec 26, 2008 | 09:56 AM
  #208
Kisada's Avatar
14 pages of tease!
When will this be released?
Dyno charts?
More stats?
How much?
Waiting list?
lol!!
Old Dec 26, 2008 | 10:00 AM
  #209
Mojito's Avatar
Deep penetration is cool! ))))
I can't wait for this d/p!
Old Dec 26, 2008 | 10:03 AM
  #210
yeah, damn thing wont come off. I have tried just about everything short of burning it off LOL. The other one is just as bad too. Must me some rare string of rash or something.
No prices just yet. we really hate to release things until they can actually leave the door. All of us that work here at one point in our lives were customers just like you and we know how much it sucks to pay for something and have to wait and wait and wait for it. This is why we won't actually release pricing and sell them until we have a solid and SHORT lead time for them. Casting takes a while but we are turning things around pretty quickly now. I would say a pessimistic goal would be mid to late February but it could be sooner. This piece is super high quality and worth the wait guys. We designed it to fit like OEM and when incorporated with the heat shield to look like stock for you CA guys that are trying to fly under the radar.
Eric
