Clutch delay valve (pill) removal complete
Old Mar 14, 2008 | 11:09 AM
tsitalon1's Avatar
Removal complete:
Took 45 minutes. I followed this guide:
http://evomoto.com/tech_info.php?tPa...5c77616b84523f
The X is exactly the same. One inportant thing to note is that it might not be neccessary to completely remove the slave cylinder from the vehicle. I did remove it, and then couldn't find the CDV. I then looked at my drip pan and sure enough it was there. So simply removing the banjo bolt completely might allow it to fall out. The CDV in the X is Plastic with a metal spring.
Impressions:
Keep in mind that I have only driven 10 minutes with it, but engagement is much more linear to me. I can now shift without any jerky movement.
I will post my impressions as time goes on.
Old Mar 14, 2008 | 11:26 AM
scottatyamaha's Avatar
^ Awesome thanks for stepping up and being one of the first to do this. Do you notice a improved shift from 1st to 2nd? That is my main concern.
Old Mar 14, 2008 | 11:30 AM
wickedchimp's Avatar
link doesnt work for me.
Old Mar 14, 2008 | 11:38 AM
NoTec's Avatar
Cool. I hope that did it.
waitin4d's Avatar
evomoto server is not stable at all... it goes on and off really frequently. try it some other time and it should work.
Old Mar 14, 2008 | 12:32 PM
Brahmzy's Avatar
Need some more info on this!!! Must give us a full report!
Old Mar 14, 2008 | 12:43 PM
DER MotorSports's Avatar
how's heel/toe downshift??
On M3s that's where removing it really shines.
Old Mar 14, 2008 | 12:47 PM
gotevo?'s Avatar
someone plz sticky this thread in the HOW TO:
Old Mar 14, 2008 | 01:22 PM
Noize's Avatar
EvoM Administrator
I would love to hear if notchiness is improved.
Old Mar 14, 2008 | 02:21 PM
STi2EvoX's Avatar
I am expecting that the notchiness is not going to be any different. The reason that I say this is because the car shifts great when shifted quickly after the clutch has been depressed, and worse when done slowly. This to me says that if it were a clutch disengagement issue that it would be the opposite. I am curious as to how the car feels when speed shifting and launching, though. I haven't launched my car, because I hate abusing the tranny, but I have noticed that when speed shifting the clutch seems to slip just for a split second before fully grabbing. This should be gone with that pill removed. Let us know...
Old Mar 14, 2008 | 02:30 PM
R0ME0's Avatar
subscribed!
Old Mar 14, 2008 | 10:17 PM
Noize's Avatar
EvoM Administrator
Mine is nothing like this.
Old Mar 14, 2008 | 11:23 PM
Talon_66's Avatar
Originally Posted by ONRAILS
I don't know why you guys are so obsessed with the notchyness. As long as you can shift it. And it shifts fine when being shifted fast i really don't see the obsession.
You buy a sports car but expect it to be super smooth. I would've bought a cts-v if thats what you were worried about.
because you cant shift with it
Old Mar 15, 2008 | 12:11 AM
ONRAILS's Avatar
It really is so bad that it inhibits you from getting into 2nd gear? holycrap
Old Mar 15, 2008 | 06:09 AM
It does not inhibit us from getting into gear, but it is a very noticeable grind/drag/notch that could be putting a wear on the gear synchronizer, which could lead to bigger problems. Also it is just plain annoying.
