PERRIN EVO X Turbo back build...
#196
OEM Downpipe weighs 5.15lbs where the PERRIN prototype is 4.5lbs
OEM Catpipe weighs 14.7lbs where the PERRIN prototype is 7.65lbs
OEM Catback weights 43.5lbs where the PERRIN prototype is 31.6lbs
There you go!
There you go!
#198
I know it was late and i didn't have time to go weigh them.
The production parts are lighter for sure.
On our final downpipe we combined the downpipe portion with the Catpipe to save weight and costs.
OEM Downpipe and Cat pipe weighs 19.85lbs
PERRIN Downpipe w/cat weighs 8.8lbs
Savings of 11lbs!
PERRIN Catback (3pcs) 27.4lbs
Savings of 16.1lbs!
Total savings of 27.1lbs!! Now we are getting closer to getting this thing to the weight of the STI!!
Savings of 11lbs!
Savings of 16.1lbs!
#199
ATM I'm thinking I'm going to go with your stage II kit. I talked to your tech dept and looked on your site, but i've yet to get a clear picture of what I should expect from this kit. I'd like to see what this should look like on the dyno.
#201
I LOVE the sound of my new Perrin CBE, nice and deep...not too loud, no droning at highway speeds. Installed it over the weekend along with my Perrin adj. 25mm rear sway bar.
Did this up on Rhino ramps in my driveway. The only tough part was separating the stock heat shield around the cat and banging off those spot welded stock nuts. The rest was cake.
#203
It's not too bad a job...no air tools required, would have been easier if I had the car up on a lift. Taking the stock CBE off was really easy since my car only has 1500 miles on it. WD-40 works great on both the hardware and the rubber exhaust hangers.
Banging off those spot-welded nuts off the cat pipe SUCKED! Use a big hammer and don't expect to ever use those stock bolts again after you beat the snot out of them.
Spreading the heat shield is easy after you remove the small nut on each side. Can you tell I used anti-seize on the new bolts?
#206
heh...im relaxing with a beer now. don't worry, i'll come through tomorrow lol.
stopped by a friends after install, he was impressed. now hes inspired to bring his gto out with me tomorrow for vids
#207
heres are some videos. i was not happy when i found out my camera was broke this morning so i had to borrow one . these are ok i guess:
http://www.youtube.com/watch?v=fambe6CvxE4
http://www.youtube.com/watch?v=rDROZ4ytz4k
my stock exhaust droned out so easy at like 3500 rpms, this exhaust has fixed that. i am idling much smoother and a noticable power increase.
PERRIN_Jeff
346
Jul 17, 2013 03:02 PM
PERRIN_JOHN
24
Apr 23, 2009 11:01 AM
