best bang for the buck intake?
Old Jul 18, 2008 | 09:33 PM
SAtown EVOx's Avatar
what do you all think is the best intake for the x at the right price?
Old Jul 18, 2008 | 09:37 PM
Mightygnu's Avatar
It depends on what the long term goal is, most intakes are the same, only big difference is AMS' is made out of Aluminum and others are made out of Stainless Steel.
Almost all the intakes are seeing the same gains, so it is really up to you.
I think Buschur's is the best bang for the buck! $209.00 is a great price!
Old Jul 18, 2008 | 09:49 PM
NewYorkJon's Avatar
Whats the Pros & Cons of Aluminum over Stainless Steel?
Old Jul 18, 2008 | 09:54 PM
Mightygnu's Avatar
Aluminum offers a few advantages: less weight and better heat transfer properties.
Old Jul 18, 2008 | 10:01 PM
xtremeboost's Avatar
We have made them both in Stainless and Aluminum . A few years back I had a friend test out the ability for each to heat transfer/retention and after testing he came back with a difference of +/- .05 degrees , which means for transporting air whichever will work .
and yeah Aluminum will weigh less -- lol
Old Jul 18, 2008 | 10:31 PM
Mightygnu's Avatar
In the end, its up to you, they are producing the same gains for the most part.
Old Jul 19, 2008 | 07:46 AM
RedlineX79's Avatar
They are all 1 foot long pipes with a cone filter at the end. Same ****, pick the pretty one! haha
Old Jul 19, 2008 | 10:56 AM
Shahul X's Avatar
weight vs $$$
Old Jul 19, 2008 | 11:07 AM
Mightygnu's Avatar
Originally Posted by Shahul X
weight vs $$$
haha. I vote for Buschur!
Old Jul 19, 2008 | 03:30 PM
meat_EVO's Avatar
COBB inlet hose and HKS drop in. cost me $140 shipped for both from RallySportDirect.com
felt great once installed.
Old Jul 19, 2008 | 07:31 PM
si_to_evo's Avatar
AEM
Old Jul 20, 2008 | 12:27 PM
qubit's Avatar
Well one difference is whether or not the intake uses the stock MAF housing.
if they do NOT use the stock MAF housing, they will probably cause the MAF signal to be adjusted an unknown amount, causing the car to run more lean.
This is a good thing, if you want quick bang for the buck, because leaning it out = more power on the X. However, most shops offering ECU reflashes require you to use either their intake or the stock one, because they cannot tell how much every other intake is changing the MAF signal.
So, the buschur racing intake uses the stock MAF housing, and the AMS one does not. I'm assuming, but not certain, that the buschur racing intake will be more compatible with other shops tuning the X than the AMS one would. However, i would guess that the AMS would show more power gains on a stock ecu, because it will lean the A/F ratio out a little more than the buschur. After you get a tune, the differences will be negligble, since the A/F ratio will be properly tuned.
This is a much more important characteristic than steel vs aluminum, IMO.
Old Jul 20, 2008 | 02:20 PM
Noize's Avatar
EvoM Administrator
Stock airbox + tune.
Old Jul 20, 2008 | 02:28 PM
06ravenmr's Avatar
u crazy i just gained 15hp over the stock box with k&n by switching to a open filter intake
Old Jul 20, 2008 | 02:53 PM
went with buschur,getting a ecutek tune sunday
