LBS. of Boost recommendations?
I had south coast mitsu put on the dejon boost controller and they put it up to 22lbs of boost. This is my first car with a turbo and everyone I talk to is amazed at the number. I am pretty sure that stock GSR X is putting out 14 lbs so the increase doesnt seem to overwhelming. I wanted to get some info on longevity with that much boost if it is a good idea or if the motor can handle. My buddy in an 04 sti says he wouldnt go that high even with all of his mods and tunes. Any advice/suggestions would be greatly appreciated.
I also have the injen cold air and the greddy full cat. Maybe a tune would be appropirate?
Someone correct me if I'm wrong but factory boost is 22.75 psi. Alot of people are setting theres around stock, I have mine set to 24 psi and it is running fine. So you could probably turn it up a little if you want.
^Yeah the 14psi is the boost in the higher rpms because of the smaller turbo and stock wastegate. it spikes to around 22-23 psi stock though in the lower rpms. unless your car holds the 22psi to redline then they have more done than just a boost controller. which would also be fine just make sure you have the supporting tune to go along with it!
