Help with boost
Old Jan 12, 2009 | 07:16 PM
jmorris1027's Avatar
So adjust the preload tighter. Do you have to really pull on the rod to get it on the wastegate flapper thing on the turbo?
Old Jan 12, 2009 | 07:49 PM
EvoX_SA's Avatar
the simple answer is yes, put some muscle into it.
Old Jan 12, 2009 | 08:13 PM
I know you gotta pull that effer, I'm asking the other guy if he has to.
Old Jan 13, 2009 | 07:17 AM
2fas4utoo!'s Avatar
UPDATE
First, Thanks all you guys for your feedback. You've been great!
We took out the Forge actuator and put back the factory unit and still is not boosting over the rod pre-set . We tested the Forge unit blowing some compress air into it and its working fine, so this variable is eliminated.
Other test we made, is disconnecting the vacuum lime from the actuator and the car will over boost, so the turbo is working...2nd variable is out. Apparently something is wrong with the vacuum hoses. The car does not have the factory vacuum hoses from the selenoid tee's to the turbo intake and actuator(no restrictors at all). But this was like that with factory turbo and Hallman manual boost controller(everything was working correcly), now I'm running the Red and hit this poblem. Definitely there is some sort of poblem there. I will keep trying to resolve this but if you have any idea or feedback it will be appreciated.
Thanks again.
Old Jan 13, 2009 | 08:30 AM
2fas4utoo!'s Avatar
Sorry overlook this. The answer is yes.
Old Jan 14, 2009 | 02:49 AM
Mad_SB's Avatar
Originally Posted by 2fas4utoo!
What Im trying to do is use the factory boost controller, using thre Ecutek. So I can raise boost. So far the factory boost control it ain't working at all. It used to work before we put in the forge actuator. Does anyone else experience this trying to use the factory boost controller?
There is no way around the fact that you have something hooked up wrong. EcuTek mapping does not change itself so either you got some of the lines crossed or unplugged the boost solenoids or something.
Go back and double check all the line routing, I'm not sure how many "pills" are in the lines but if anny of them got removed or moved to a different location....
My inital thought is that got the lines reversed at the WGA and pressure nipple, but again I have not checked to see if there are any pills in that section of line that would cause this issue.
Old Jan 14, 2009 | 02:51 AM
Mad_SB's Avatar
UPDATE
Thanks again.
There is your problem man, put the stock lines back on.
Old Jan 14, 2009 | 08:37 AM
TTP Engineering's Avatar
Yes the exact same bleeder hose configuration is needed in order for the solenoids to do anything.
Old Jan 14, 2009 | 08:51 AM
2fas4utoo!'s Avatar
UPDATE
First-Thanks, I appreciated everybody's input and help.
I put back the factory hoses. What I believe went wrong is the restrictor pill that was on the turbo housing side is needed. I ran a test disconnecting the hose after the tee that goes to the selenoid and it overboost (it didn't do this before)so I think I resolve the poblem. When I connect it back it remains on 20PSI so I believe we are good now. Im meeting wih Ecutek tuner this afternoon to adjust the boost throught the ecu to see if it works.
I'll keep you posted. Thanks again
Old Jan 14, 2009 | 06:22 PM
2fas4utoo!'s Avatar
UPDATE
Its working , thank you all!!!!!!!
Old Jan 15, 2009 | 01:20 AM
runovr 33's Avatar
UPDATE
std pill size is 1.17mm
.10mm of a change makes abig differance smaller for more boost larger for less
tightening the gate ramps the turbo boost on harder giving more punch out of
a gear change
Old Jan 16, 2009 | 07:03 AM
2fas4utoo!'s Avatar
Thanks for the input, I thought about this and order the GST pill. It should arrive today. Currently I'm hitting 24PSI so as soon as I switch I'll post the jump on boost.... or overboost.
a gear change
svt_lightning01
Mar 31, 2011 01:08 PM
kouzman
Apr 3, 2008 04:35 PM
Thegame
10
Jul 25, 2007 12:01 PM
[Cyanide]
Aug 12, 2004 10:21 PM
ogdelsol
Aug 15, 2003 10:08 PM
