Injectors help!
Old Nov 1, 2008 | 10:24 PM
kirkklau's Avatar
Question
guru or anyone,
have you guys found a company that makes 1000cc+ high impedance injectors?
thanks guys
kl
Old Nov 2, 2008 | 11:24 AM
Guru's Avatar
I have. Getting details on what is needed to make them work on the X. Pricing looks decent. Probably around $100 an injector.
Old Nov 2, 2008 | 08:18 PM
kirkklau's Avatar
Smile
thanks, pls let me know where to get the high im injectors or low im ones with resistor pack of 1000cc+
thanks
kl
Old Nov 2, 2008 | 10:59 PM
kirkklau's Avatar
Question
Darryl @ ultimate-racing,
is the high im 1000cc and fuel pump going to be out soon? when?
thanks
kirk
Old Nov 4, 2008 | 05:01 PM
kirkklau's Avatar
Smile
guru,
how, have you found out?
thanks
kl
Old Nov 4, 2008 | 11:39 PM
mrfred's Avatar
Originally Posted by Darryl@Ultimate Racing
The X uses high impedance injectors. We've got an 800cc high impedance injector kit for the Evo X available
Darryl
www.ultimate-racing.com
Wow, that seems a bit old-tech low performance. Have you measured the latency of the stock injectors?
Originally Posted by DrivelineSales
The Evo X has high impedance injectors. With our 35R, we had to run 1000cc low impedance injectors w. an AEM Peak and Hold Injector Resistor Box.
Using a ($20?) resistor pack from an Evo 8/9 with low impedance injectors should get around the need for an external injector driver box. The peak and hold box will improve latency consistency and lower the latency a bit though, so it does have some advantage over the resistor pack approach.
bbyevo8u
15
Nov 2, 2016 06:04 PM
bigturboevo80
Nov 11, 2010 10:13 PM
darkmitsu
Lancer Aftermarket Forced Induction Tech
May 1, 2008 08:15 AM
Juiced
Oct 16, 2005 04:41 PM
