clutch master cylinder
Old Aug 8, 2009 | 06:47 PM
  #46
boostin20's Avatar
Originally Posted by carrito.net
7/8" but I recommend 3/4" for must cases, We didn't know exactly and I ordered the larger one, but it is a bit overkill, the smaller diameter 3/4" works much better... Plus is rebuildable, height adjustable and way stronger than the Evo 9 or stock one
Thank you for the info!
Old Aug 8, 2009 | 06:54 PM
  #47
tsitalon1's Avatar
Anyone have any hints on how to even get to the Damn MC. I curently have the tranny and clutch out and still cannot get my hands on the reservior hose at the MC or easily get the output clip off the MC...What am I missing? I tried from above and below.
Old Aug 8, 2009 | 07:21 PM
  #48
PR_Mivec's Avatar
try the side....
remove the brake mc and you are done....
Old Aug 10, 2009 | 07:40 AM
  #49
DG Motors's Avatar
solution.
https://www.evolutionm.net/forums/ev...ml#post7377684
There is our solution. We are offering this service.
Old Sep 19, 2009 | 01:48 AM
  #50
jk68x3's Avatar
I will be attempting to install the tilton 76 series next week, I'm just waiting on the braided clutch line. If all goes well I will put a full wright up on here. Justan FYI the tilton cylinder is cast and not plastic and looks 2 be an easy install. The cylinder was $120+ shipping and I got it from Pegasus auto racing got it in 2 days
Old Sep 19, 2009 | 10:19 AM
  #51
garageGT's Avatar
Originally Posted by feli3344
My clutch master cylinder has broke twice since clutch install i got act extreme pressure plate with street disk anyone know a fix to this?? Eric from ams said its a common prob but its driving me nuts every time it breaks.
I dont think ACT tested this clutch before they released it !
With that heavy pressure plate, the AMS ring did not help. We broke it twice as well. Got a exedy twin plate, pedal feels super light and there are no issues so far.
Our last resort is a custom MC if we break again.
this was right before we broke the MC..
http://www.youtube.com/watch?v=j94Ji...e=channel_page
Old Sep 19, 2009 | 10:42 AM
  #52
Clipse3GT's Avatar
Awesome keep us updated!!!
Old Sep 22, 2009 | 06:11 PM
  #53
jk68x3's Avatar
Update. The tilton master cylinder is not the best option. After running around trying 2 get fittings I ended up at a local catapillar dealer the shower be that the fittin on the top will leak. They tapped it for me to make it hold an o-ring so it would not leak. I have been working on the car for about 10 hrs and havnt even gotten the clutch pedal out. If n e 1 would like more details feel free 2 post or pm me
Old Sep 23, 2009 | 04:08 AM
  #54
hawaiian_evo's Avatar
I got the ams ring and a exeddy twin disk. Like garagegt says the pedal is light so i hope the ams ring can hold it together
Old Oct 18, 2009 | 08:38 AM
  #55
Sicks's Avatar
just the other night, i was pulling out of the gas station, pushed the clutch pedal in to put it in first aaaaaand.... POP! pedal went to the floor and stayed
i immediately suspected the MC. i looked under the car and yup.. there was my precious fluid on the ground.
i have the exedy twin HD and AMS ring installed. the shop hasn't opened her up yet, so i'm not sure whether it was the cylinder itself splitting, hose, fittings or what. i'll keep ya posted.
to : your flawed plastic (and epoxy glued ) master cylinder must be recalled. obviously, this has become a rather common problem for us evo owners.
Old Oct 19, 2009 | 06:25 AM
  #56
SineEVO's Avatar
Mine broken too, 15 min after install of Carbonetic twin. F....kin plastic cylinder!
Old Oct 19, 2009 | 07:55 AM
  #57
.MM's Avatar
.MM
pretty sure mine just broke as well, 50 feet of driving after installing exedy twin HD
trying to come up with solution...
Old Oct 20, 2009 | 01:34 PM
  #58
SineEVO's Avatar
Uf, sorry man. I am waiting for new cylinder and AMS reinforcement ring. Hope, this will work.
Old Oct 21, 2009 | 12:39 AM
  #59
Narmy77215's Avatar
I have around 1200 miles on my exedy twin hd and oem mc is fine.I hope this does not go out anytime soon.
Old Oct 24, 2009 | 12:42 PM
  #60
Sicks's Avatar
ok, got the car back tues. apparently a snap clip well.. snapped on a hose from vibration and it popped off causing me to lose the fluid.
so kudos to AMS your reinforcement ring is still doing the job!
