Evo X bolt on Garrett GT30R turbos
the shop runs when the dyno wont be used, which is rare....
its normally 10 degrees cooler on the dyno than outside...
(as per our discussion earlier over IM)
i just did a retune onthe 3076R with a 3 port solenoid... spool was close to thehallman pro rx, but with less taper... 3 port rocks on this thing (thanks to help from Jon @ HB speed and bryan at GST for the setup).... it was quick and easy... first pull 22 psi, second 24, then 26-27psi...
the turbo is laggy.... i have no surge issues... but im not overly impressed with the power....
358/290 at 27psi (the car stock was 230/240).....
cheers
cb
cheers
cb
we have tested ours... and are still testing..
stock o2 housing (which i view as a restriction)... stock downpipe to our resonated and dual muffler catback... cbrd intake.... cbrd vertical fmic..... DW 800cc injectors
26.7 psi we saw 357whp 298wtq in 80 degree heat with I believe 40% humidity.... the car on the stock turbo was in the 320-328whp range, with torque around 310-315...
we are seeing ABOUT a 40whp jump up top past 4995 to redline, but losing 90wtq at 3800 rpm....
im going to do some experimenting with the WG actuator and boost pressures to see if the power goes up.
We are one of the official garrett test partners, and they have been very open to our findings.
cheers
cb
cheers
cb
On another note I agree what others have said, this was open market for buying the turbo with nothing being said about needing more testing. But seems like no one is getting good results? Not even decent results..... I hope a rep from Garrett can chime in
I am just very curious because I almost went ahead with the purchase of this turbo, but I would be furious by now.....
I'm getting compressor surge at part throttle 5psi while letting off slightly in 2nd-5th gear.
I also got compressor surge at WOT in 5th gear where as soon as my boost climbed past 20 psi at 3600-3800 rpm's you could hear a quick choo choo choo then it was fine at 4k+.
4th gear Spool Test, WOT at 2k and let off when it hits 20 PSI
Stock Turbo = 2800 stock Mivec, 2550 tuned Mivec
GT30 = 3600 tuned Mivec (although it might need more tweaking to enhance spool assuming it doesn't induce compressor surge)
Those logged g/s above and in a previous post of yours in this thread are totally incorrect. What are you using to log them? The stock Evo 10 turbo at full song (about 19-20psi up top) logs about 40 lb/min which is 305 g/s. The 3076 at around 23psi I was logging about 47 lb/min which is 355 g/s.
IMHO, you should be logging knock with Evoscan.
3rd gear pulls
- GT30 @ 23 psi @ 4000 tapering to 22 psi by 7000
- Stock Turbo @ 26 psi from 3500 to 5500 then tapers to 20 psi by 7000
RPM---GT30 Airflow--Stock Airflow
3500 ------ 281 ---------- 468
3750 ------ 375 ---------- 462
4000 ------ 456 ---------- 488
4250 ------ 487 ---------- 513
4500 ------ 525 ---------- 525
4750 ------ 537 ---------- 544
5000 ------ 556 ---------- 569
5250 ------ 581 ---------- 594
5500 ------ 619 ---------- 613
5750 ------ 631 ---------- 625
6000 ------ 650 ---------- 638
6250 ------ 669 ---------- 644
6500 ------ 700 ---------- 656
6750 ------ 725 ---------- 669
7000 ------ 756 ---------- 669
7250 ------ 781 ---------- -
7250 ------ 809 ---------- -
I am also logging knock and besides a few trickles of 1-2 knock counts as boost comes on and past 6500 the logs are free of any moderate or worse knock. My tune is basically the same as with my stock turbo so the higher flow sections are likely a bit rich once the turbo outflows the stocker. I'll know more once I have AFR's logged hopefully tomorrow night. I tried to tune out the trickle knock I got on the stock turbo and it was no use. I even dropped in 100 octane fuel to test the theory and there was still an occasional tickle at 6500 no matter what I did with increasing fuel or reducing timing.
Hiboost, what kinda injectors are you running and what are you logging the airflow with? The airflow numbers are way off, the most I've seen on a stock turbo was around 315g/s.
Spark blowing out? Or possibly too rich?
So its becoming more apparent now that tuner shops are FINALLY commenting...... looks like the Garret turbo for the X has completely flopped...
HiBoost hopefully u will see different results, but now that GST and CBRD are commenting its looking like you shouldnt be expecting much
Of course, one bad apple does not make a bad tree. I'd like to see another come through the shop at some point to totally make up my mind.
- bryan
Yeah that is confusing me, has anyone tested turbo outlet temps with a stock turbo at 20 psi versus the GT30 at the same 20 psi? Maybe a permanent boost leak in the compressor side or some kind of design flaw that is causing the air to overheat so it flows more but with hotter air and worse power?
To eliminate one possible issue with the surge, have you tried the stock BOV? I just find it odd that you got it on the stock turbo too.
It's quite possible that EvoScan just needs to be divided by 2. It is just a formula. In this case, you were flowing about 335g/s with the stock turbo which is in the same ballpark as the other guys, and the Garrett is flowing 405g/s or about 53lbs/min.
I've still got my stock BOV and will test to see if I get the same surge behaviour this weekend. Likely I'm just at the spool limits this laggy turbo will tolerate even with the anti-surge ported compressor housing.
http://www.translatorscafe.com/cafe/...ond-%5Bg/s%5D/
either way the Evoscan formula is incorrect, which is ok, it's still in beta.
I thought that too at first but 335 g/s is 44 lb/min
I think the OBD2 datalogs I have were around 38 lb/min according to this:
https://www.evolutionm.net/forums/ev...ock-turbo.html
Once you hit 5500 RPM's that turbo was maxxed at that lb/min flow rate, the GT30 certainly seems to have longer legs up top, we will see.
yeah beta is beta. :P
btw kudos on all the data you share.
Hold your head high if you do find out it sucks..... you have will be able to do the swap in a fraction of the time now that yu have done it once! and you have a handful of kick *** parts to strap to a quality turbo. (knock on wood...i still hope the Gt30 works, i had high hopes
I remember when the X first came out, someone measured the outlet temps on the stock turbo and I want to say they got into the 400F range! It was waaaaay higher than expected. I guess part of sitting in the oven of the back of the engine bay.
