Interesting weight find & other observations today which swapping the clutch...
Old Jan 17, 2009 | 08:14 PM
goofygrin's Avatar
ACT streetlight flywheel: 12.25#
Stock OEM flywheel: 12.25#
So... is it worth it? Maybe. It's possible that the weight is actually shifted more toward the inside of the flywheel therefore making it feel lighter than the OEM (weight on the outside of a spinning disk has more inertia than weight on the inside -- yes, yes physics nerds, mass).
Random observations:
- having someone who's done hundreds of VIII and IX clutches do your X is WAAAAAAY simpler than doing it yourself. I would have had 0% chance of completing the job in a weekend, let alone 1 day (other than the tools I don't have [like a hoist and the special one to remove the axles] there was just so many little things that KevinD just knew that made the job simpler).
- Diaqueen smells like.... money. Wet, moldy, been in the lockerroom over christmas break money.
- The 100 clips that hold the undertrays on looked like a lot of fun to take off.
- A stock clutch makes a lot of dust when it's down past the rivets
- The UR o2 housing is WAY easier to remove when the axles are out and the xfer case is moved out of the way
- R&R a VIII alternator is a very cuss-worthy job and I don't want to have to do one
ETA: Mitsu also put a hanger on the top of the transmission, making it a lot easier to use a hoist to get in and out (balanced) vs. a VIII/IX.
Old Jan 17, 2009 | 09:53 PM
STi2EvoX's Avatar
Nice info. How do you like the new clutch? How's the engagement point now, since the X's clutch pedal is, stupidly, not adjustable?
Old Jan 17, 2009 | 10:01 PM
Talon_66's Avatar
Buschur says it is adjustable
Old Jan 17, 2009 | 10:21 PM
STi2EvoX's Avatar
Nope, he said in a later post that he was mistaken. It is in fact not adjustable, just like every other shop has said.
Old Jan 17, 2009 | 10:26 PM
goofygrin's Avatar
The engagement point moved down a bit (maybe an inch?). It now feels like my wifes G35 Coupe ('03) in stiffness and engagement (meaning more on/off vs. slippage and a bit stiffer than stock).
Old Jan 18, 2009 | 08:16 AM
toshibakoludo's Avatar
Wink
So STi2EvoX do you see that the stock flywheel is a light one? Or do you still not think so
halfnhalf83
31
Oct 7, 2015 08:23 PM
PLP7
10
Oct 30, 2014 11:17 AM
joseph143
Feb 19, 2014 07:42 AM
EGbeater
Oct 18, 2011 12:58 PM
MitsuJoe
Aug 1, 2004 01:59 PM
