help!!!!
Old Mar 3, 2009 | 02:17 PM
4myX's Avatar
help!!!!
Pulled the transmission out again to put in a different act clutch and flywheel and the lock collar for the throw-out bearing is not re-usable it got messed up. To get a new one I have to buy a new pressure plate from mitsu. Does anybody have the old pressure plate set up and locking collar from doing a clutch swap? if so would you sell it to me? Thanks let me know asap so I dont order a new one.
Old Mar 3, 2009 | 05:18 PM
4myX's Avatar
bump!!
Old Mar 3, 2009 | 05:21 PM
STi2EvoX's Avatar
Contact russell at mitsuparts. All OEM mitsu parts, for far cheaper than dealer prices. That's your best bet if you ask me.
Old Mar 4, 2009 | 06:24 AM
4myX's Avatar
Its still about 150.00 and Ill have a stock pressure plate for no reason. If I need to I will buy one buy hoping somebody still has there old setup
Old Mar 4, 2009 | 06:42 AM
hcope316's Avatar
If you dont mind me asking what happen to the first ACT setup. Did it give you problems are did you upgrade
Old Mar 4, 2009 | 07:24 AM
4myX's Avatar
no problems at all, but I was running the street disc with the power im making now, so I wanted to upgrade
Old Mar 4, 2009 | 09:49 AM
hcope316's Avatar
what is the most power the street disk can hold before upgrading
Old Mar 4, 2009 | 12:42 PM
4myX's Avatar
520 tq
Old Mar 4, 2009 | 01:34 PM
Evo4u2envY's Avatar
You could probably use it off an 8-9 evo too..im pretty sure the only difference in the clutch/flywheel setup in the X is the flywheel....
