PERRIN Oil Catch Can Placement
Old Mar 15, 2009 | 12:50 PM
Nammy's Avatar
I haven't seen many threads regarding oil catch can placement and installation, so I thought I'd share a picture of where I placed mine. I used the straight bracket on the bottom side of the catch can, and attached the other end to the air intake box bolt. It is kind of tight, but the wiring harnesses in this area can be tucked out of the way to make room for the catch can. There is an angled plastic lip that is part of the air box down by the bolt. When you bolt down the catch can, the bracket will mark up this plastic lip a little bit. It's nothing serious, but you could probably space the bracket up with some washers so that it clears the plastic lip, and it should still clear the hood as well. If you face the input/output nipples on the catch can toward the motor, then the hood will clear the hoses without problems.
Old Mar 15, 2009 | 08:03 PM
starmax's Avatar
looks great!!
Old Mar 16, 2009 | 08:34 PM
THEMEMPHISFORCE's Avatar
What lines did you hook this into?
Old Mar 16, 2009 | 09:05 PM
Nammy's Avatar
It goes between the valve cover vent and turbo inlet pipe. If you look at the back side of your turbo inlet pipe, it is the larger of the two lines that connect to it. Follow the line to the valve cover to see where the other side connects.
Old Mar 16, 2009 | 10:50 PM
accrane's Avatar
this is a definitely a must for those running aftermarket intakes with no input for the valve cover vent.
Old Mar 17, 2009 | 01:17 AM
LVSBB6's Avatar
Has it catch any oil yet?
Old Mar 17, 2009 | 06:40 AM
Nammy's Avatar
Not yet, but it has only been on there for about 25 miles. When I took the stock line out, I noticed that there was a little bit of oil residue in there. This is with 5500 miles on the car.
Old Mar 17, 2009 | 02:36 PM
EvoXstylin's Avatar
I like the placement of that. Good job.
Old Mar 18, 2009 | 04:40 AM
DarwinX's Avatar
Good job, looks nice.
Can you take some pic's showing the hose attachments?
I guess you won't be needing that hood prop rod anymore.
Old Mar 18, 2009 | 02:30 PM
combatp21's Avatar
Looks good. It will help in a long run having a catch can.
vortico
Jun 21, 2017 11:38 PM
RussellM
MitsubishiParts.net - WA
Jul 20, 2015 04:48 PM
JmacsEVO
Jul 10, 2009 07:09 PM
rodman
May 4, 2008 09:42 AM
cij911
Dec 12, 2006 02:55 PM
