X rs gearbox....
Old Mar 17, 2009 | 02:38 PM
markmec78's Avatar
X rs gearbox....
Anyone know of any other front diffs failing on the X rs??
Im trying to locate a front diff for mine as the gearbox is being rebuilt with new bearings etc....
I was thinking a cusco front LSD, any traders on here ship to the u.k.??
Any all help much appreciated.
See pics for fault/damage..
One of the main pins had made its way out of the diff due to roll pin failure and worked it's way through the gearbox casing, the car still drove fine with no nasty noises or faults other than oil leak....
I have more pics I just have to resize them, I will post them soon..
Old Mar 17, 2009 | 02:42 PM
markmec78's Avatar
pics...
pics of the casing showing the wear/hole...
Old Mar 17, 2009 | 02:43 PM
markmec78's Avatar
pic..
The failed pin sticking out.....
Old Mar 17, 2009 | 02:50 PM
LVSBB6's Avatar
what caused the damage?
Old Mar 17, 2009 | 03:03 PM
markmec78's Avatar
The pin in the picture has another pin running through the centre of it which snapped allowing the larger main pin to work it's way out....
The picture of the gearbox casing shows the wear caused by the pin rotating on the diff and wearing through the casing, which is the cause of the oil leak.
If it hadnt have leaked oil i wouldnt have known there was a fault...
Old Mar 17, 2009 | 03:10 PM
LVSBB6's Avatar
Is your car modded with huge power? what do you think have caused the snap?
It should be covered under warranty i suppose, but if you wanted to upgrade instead there`s also Ralliart who makes replacement LSD.
Old Mar 17, 2009 | 03:16 PM
markmec78's Avatar
Yes mate, but only running 410bhp 400lbs....
I think the failure is a manufacturing fault potentially, but how knows??
It's not covered under warranty, beacuse it's a jdm import the RS was not officially imported to the u.k. To the point that I cant even order the parts I need from my local dealer for the same reason.....
Im trying to locate the trader section on here to make some enquiries......
Could you recommend any????
Thanks
Mark
Old Mar 17, 2009 | 03:18 PM
MarkM's Avatar
It's covered under warranty, beacuse it's a jdm import the RS was not officially imported to the u.k. To the point that I cant even order the parts I need from my local dealer for the same reason.....
Thanks
Mark
Mark, be careful mate, the RS definitely has different ratios to a GSR 5MT, both US and UK, have you tried NigelS from MLR, failing that I'd email japanparts, what they don't have they can usual source reasonably quickly
Old Mar 17, 2009 | 03:29 PM
markmec78's Avatar
Thanks mate, I knew the ratios were different, I havent tried nigel yet....
I will try japanparts.......
Have you used them before??
Mark
Old Mar 17, 2009 | 03:36 PM
Papi4baby's Avatar
I think someone else is Russia had the same thing happen to him.
Old Mar 17, 2009 | 03:47 PM
goofygrin's Avatar
That's what I was thinking. His car was a USDM car though. But the pictures look *exactly* the same.
Edit: here's his thread: https://www.evolutionm.net/forums/ev...ne-manual.html
Old Mar 17, 2009 | 03:48 PM
LVSBB6's Avatar
I have ordered a few parts from Japanparts.com already, find it quite reliable and quick service. Hope it works out for you.
Old Mar 17, 2009 | 03:49 PM
goofygrin's Avatar
Russia:
UK:
Old Mar 17, 2009 | 03:50 PM
markmec78's Avatar
Any links to pics etc?
It would be interesting to see the outcome of the repairs etc.
What a nightmare come true, I have only owned it a few weeks, driven it twice before it started leaking.....
Old Mar 17, 2009 | 03:51 PM
goofygrin's Avatar
I updated my post (and made another post). It looks *JUST* like the pictures you posted.
