Motor blew up :(
man that sucks bro. Now I want to take off my parts and go back to stock. I have the AMS intake and UICP, I've had the too lean (bank 1) SES code before, but it hasn't come back since I've cleaned my MAF. Should I be fine? or will my motor blow too?
Also keep in mind my car was running around 3.2-4k rpm *depending where i was* For around 19-21 hours straight, minus the 10mins to stop for gas and walk my dog a few times.
I've always lived by the motto, if your gonna play the modding game, don't be scared to break something. And if you break it, make it better/stronger. If your scared then put ur car back to stock. Otherwise you won't enjoy your car if you think its gonna break everytime you feel the need to push the pedal down a little further. Just my outlook on it.
Although 25 psi is very close to the 23 psi max stock,
Concur with the opinion that with a MBC you need a tune.
If the oil pump went first and starved oil the cams usually seize first and just lock up, not blow up. You would have seen the red oil pressure light too, way before anything seized.
Looks like the rod broke, the piston is still intact, guessing detonation stress. Maybe the 90 didn't help.
thanks for your service, stay safe
so i see alot about the mbc "maybe" causing this.
I just put an mbc on my stock x and got a pro tune. Am i at risk of these issues? What about the tune do i need to make sure they addressed? Its at 23.8 psi right now, but wouldnt mind going higher down the road.
put it back to stock and take it to some mitsu dealer you never hear of on here. They wont know. Every dealer I have been to never heard on evom. better yet delete the part about the mods. dont blow your hard earned cash yet, buy a house when you get back.
