NEW: Blitz EVO X Surge Tank
Old Mar 24, 2009 | 10:45 PM
seven_227's Avatar
Capacity: 2.8L (Twice the capacity of the stock)
Two-piece construction
Blitz 800cc injectors (Sold separately)
Before: 366.7 PS , 460.4 Nm
After: 374.3 PS , 491.1 Nm
+ 30.7 Nm
Higher quality pics of the C-Ti exhaust:
Old Mar 24, 2009 | 10:51 PM
jackygor's Avatar
that noiceee
Old Mar 25, 2009 | 12:54 AM
PnutButterWolf's Avatar
holy ****! thats awesome!!
Old Apr 11, 2009 | 02:27 AM
MACH3EVO's Avatar
have to give it to blits,
nice work.
Old Apr 11, 2009 | 07:07 AM
STi2EvoX's Avatar
Uh, that's an intake manifold and plenum, not a surge tank. A (fuel) surge tank can be in-tank or out, and is simply a separate canister that is basically a mini gas tank with an auxillary fuel pump that supplies fuel to the engine in the event that the primary pump is starved when the fuel sloshes in the tank during hard cornering. It has nothing to do with the intake manifold or any part of the intake system. This is typical of JDM companies that don't know how to properly translate into english what said part actually is. This is what a surge tank is: http://www.flatironstuning.com/shop/...urge-tank.aspx. Hope this helps...
Old Apr 11, 2009 | 09:06 AM
ChopShop's Avatar
now that is great looking intake mani
Old Apr 11, 2009 | 11:12 AM
seven_227's Avatar
Yes it's an intake manifold, a surge tank is the common name for a fuel surge tank, but the term surge tank could also be used for an intake system integrating a surge tank too.
In Japan most manufacturers call them surge tanks.
"A surge tank structure in an intake manifold has a serge tank to which a plurality of branch tubes are joined at one end. The branch tubes are joined at the other end to a cylinder head mounting flange, and one end of each branch tube in the surge tank is enlarged to have a horn-like shape. The serge tank comprises a main body and a top plate. The main body has through holes provided therein for accepting the branch tubes and has its top side opened. The top plate is joined in a plane to the top of the main body. The main body has a bottom which has engagement recesses formed by raised portions, so that each engagement recess has a horn-like surface that conforms to the horn-like shape of one end of each branch tube."
Intake Manifold
Surge Tank
Old Apr 11, 2009 | 11:21 AM
ZevoX's Avatar
how much is this piece?
Old Apr 11, 2009 | 11:32 AM
seven_227's Avatar
MSRP $1675 (conversion of yen) on the Japanese Blitz website.
Old Apr 11, 2009 | 02:27 PM
Evo a Mula's Avatar
what kind of power these making
Old Apr 11, 2009 | 03:05 PM
Project_Evo's Avatar
Wow!
Old May 10, 2009 | 10:21 AM
WiCkEd-FaSt's Avatar
How much for the Blitz C-Ti exhaust?
Old May 11, 2009 | 11:13 AM
LVSBB6's Avatar
Blitz ftw!
Old May 11, 2009 | 12:07 PM
Edo Performance's Avatar
we will be having one in stock by end of this month! if you are looking for a good price, please PM us.
Thanks
Edo Performance
Old May 12, 2009 | 11:30 AM
LVSBB6's Avatar
^Does OEM injectors fit on this tank?
