Ceramic vs Carbon
Old Apr 16, 2009 | 10:22 AM
Boba's Avatar
Question Ceramic vs Carbon
So can't decide between Exedy Twin HD and Carbonetics Twin
Which one will be better for daily driving and not often drag?
Please help!
Old Apr 16, 2009 | 10:26 AM
o7'silvermax's Avatar
you mean which is better for daily as in ceramic or carbon not brands .....the carbon will burn out quick in daily driving so i would go with ceramic
Old Apr 16, 2009 | 10:27 AM
Boba's Avatar
yes
Old Apr 16, 2009 | 02:50 PM
Guru's Avatar
Carbon lasts a LONG time. Never had to rebuild a carbon twin or triple. Carbon is easier to drive on a daily basis. Smoother engagement, less harsh.
Old Apr 16, 2009 | 02:54 PM
that is true but slipping the carbon is what kills it and on daily you will slip it alot
Old Apr 16, 2009 | 06:56 PM
slonez's Avatar
I'm confused now.
Is it brand dependent?
Old Apr 16, 2009 | 08:25 PM
Boba's Avatar
I read that Carbonetics not actually poor carbon, but carbon-ceramic plate. It means that there will be no such problems as with usual carbon. Only you need 500 miles brake in period. What do you think guys? Whether it works on the EVO X?
Old Apr 16, 2009 | 08:54 PM
Guru's Avatar
Yes they have EVO X application. You are right they are not a carbon carbon clutch but rather a carbon composite. I've used them on many cars and it is by far the best multi-plate clutch I have used.
Old Apr 16, 2009 | 09:56 PM
slonez's Avatar
Price for Carbonetics twin?
Old Apr 16, 2009 | 11:08 PM
SiC's Avatar
SiC
According to ORC (another popular clutch manufature) the twin metal is good for street, drag racing, drifting, and circuit racing. The twin carbon is good for street and circuit racing.
The carbon is suppose to have the longest life but I've seen people burn up carbon clutches pretty quickly...... Carbon clutches take some time to warm up and if you don't let it warm up, it'll slip and cause some excess wear. I think that is why my friend fried his pretty quickly.
Here's the graph by ORC
just in case you don't read Japanese the graph reads Light Clutch, Carbon Clutch, Metal Clutch, & 1000F on the lateral column and Street, Drift, Circuit, and Drag on the horizontal column. Triangle meaning not so good, circle meaning good, and star meaning best.
Here's another graph by ORC
Left to right is the stock clutch, light clutch, carbon clutch, and metal clutch
The graph going clockwise starting from the 12 o'clock position is clutch slipping (riding the clutch), heat resistance, life, price, pedal pressure, & shift feeling.
According to these graphs, the metal clutch seems to be the "all round" clutch.
BTW, I'm running the Exedy Twin Metal and love it
Old Apr 16, 2009 | 11:34 PM
tomatoEVO's Avatar
SiC, seem to have any problems with the cylinder problem that some people were having? I know it's made of plastic, does it work well with the Exedy?
P.S. who the heck even sells the Exedy?
Old Apr 16, 2009 | 11:52 PM
SiC's Avatar
SiC
I don't think I have heard of anyone breaking a master cylinder with a twin disc setup. I have only heard of them going out with the ACT clutches. The most likely reason for this is because the ACT uses a single disc setup which requires more clamping force from the pressure plate. Since the pressure plate pressure is much higher, it makes the pedal a lot harder to push in too. This puts a lot stress on the clutch's hydraullic system and of course the weakest link will fail. In this case, it seems like the plastic master cylinder is the weakest link.
On a twin disc setup the pressure to hold the discs do not need to be as high as a single disc setup. That is why the pedal pressure is a lot lighter (barely harder than stock) and the master cylinders do not go out on them.
Old Apr 17, 2009 | 07:52 AM
tomatoEVO's Avatar
Good to hear, thanks for the info.
3gEclipseTurbo
Jan 21, 2016 09:26 AM
real fast
Jan 29, 2015 04:55 PM
varner88
23
Nov 21, 2008 07:50 AM
blackonblackevo
24
Jun 11, 2007 07:03 PM
ez76
19
Sep 7, 2004 04:20 AM
