HKS intake install
Old May 9, 2009 | 08:17 PM
want_jdm's Avatar
HKS intake install
Just installed my HKS super induction kit. Everything seems to be working well, except for when I step on the gas all the way.
It seems to be spooling up alright, and as soon as the boost kicks in it takes off really great. Then all of a sudden it chokes, and then boosts hard again. It seems to only do this for gears 1 & 2.
Any ideas?
Btw, the only things I got installed is the HKS kit and and ARC intercooler. All hose clamps appear to be fastened very tightly as well.
Old May 9, 2009 | 09:26 PM
sikwititevo9's Avatar
vacuum leak sounds like go back and check all the lines to the intake and check all the clamps. might look tight but could be loose.... just double check everything
Old May 9, 2009 | 09:41 PM
EndlessRed's Avatar
make sure you have everything that goes to the inlet pipe installed as it should, and all the clamps are tight. if you installed the hose clamps using a flat head, i suggest using a socket wrench or a wrench instead.
by the way, what does it look like?
Old May 9, 2009 | 10:21 PM
want_jdm's Avatar
thanks. I'll take a look at it when I get a chance.
I'll take pictures too
Old May 10, 2009 | 04:00 AM
MarkM's Avatar
Did you seal the MAF to the intake pipe, it's not a great fit imo
Old May 10, 2009 | 12:23 PM
want_jdm's Avatar
hum i didn't think about that. what did you use to seal it?
Old May 12, 2009 | 01:44 PM
want_jdm's Avatar
Update: Just talked to the guys at HBSpeed, and they think the intake is causing the engine to run too lean. The sudden cutoff of power is likely a cpu self-defense mechanism to reduce chances of damage to the engine.
Old May 12, 2009 | 05:10 PM
EvolvedVIII's Avatar
I would think the car would just go into limp-mode instead of doing what your car is doing. Who knows.
Old May 12, 2009 | 05:33 PM
VRSF Tiago's Avatar
Most likely running too lean due to the intake.
The car won't go into limp mode, it'll just studder and it'll feel like you hit a temporary wall.
Old May 12, 2009 | 11:21 PM
tomatoEVO's Avatar
OP, your car tuned?
Old May 13, 2009 | 12:08 AM
want_jdm's Avatar
Originally Posted by tomatoEVO
OP, your car tuned?
not yet. Kinda want to wait until i get my UICP first week of June. Then I am getting down pipe & test pipe with cobb access port custom tune
Old May 13, 2009 | 10:34 AM
MarkM's Avatar
My HKS was fine on my standard tune, even when I added a test pipe and exhaust it didn't cause any issues.
Old May 13, 2009 | 02:24 PM
tomatoEVO's Avatar
yeah so it's gotta be an install issue.
Old May 13, 2009 | 09:03 PM
want_jdm's Avatar
well i'm gonna re-install again tomorrow. Just doesn't make sense though. There is no need from pressurizing this area of the system. You could very well just take the damned thing off and it should run fine, other than getting crap into the engine.
Ya know?
Old May 13, 2009 | 09:12 PM
Ya know?
If you want to bring it over tomorrow I can look at it.
abrar
Jan 1, 2016 04:07 AM
deej1
Sep 27, 2015 01:55 AM
importdps
Import DPS - Philadelphia, PA
37
May 24, 2012 06:57 AM
BadazzCR
84
Dec 26, 2011 01:03 AM
Sean@Iveytune
Jan 10, 2011 11:41 AM
