Nisei UICP Fitment
Old Jun 8, 2009 | 11:50 PM
antics22's Avatar
how far down are you pushing the pipe and the coupler onto the turbo outlet? from looking at your pics, it looks like your lower clamp is too high up. The clamp should be sitting right along the edge of the hose... the hose should overlap the turbo outlet pipe by just the thickness of the t-bolt clamp and over the bead on the pipe...
Something looks off....
Old Jun 9, 2009 | 04:34 AM
Keepster13's Avatar
I have the two piece as well. Fitment was a slight issue, but everything seems fine. I also have a Perrin FMIC so that might have pushed things around. From the photos it looks okay to me..idk.. I agree with antics22, the clamp location could be adjusted.
Old Jun 9, 2009 | 08:47 AM
VRSF Tiago's Avatar
Originally Posted by 5harkology
Does anyone have any fitment issues with this piece?
My connection to the compressor outlet pipe is off. I tried loosening all the clamps and bolts and re-adjusting but the two mounting bolts above the intercooler don't allow further adjustment in the direction needed.
I will try and snap a couple pictures.
Looks like an installation error to me. Move the coupler closer towards the UICP and put the clamp about 2-3 mm from the end of the coupler and it'll give you more room to work with.
Even from your pics it's tough to understand what the fitment issue is considering everything looks like its bolted up tight.
Old Jun 10, 2009 | 09:25 AM
mikevoSE's Avatar
I have the same issue as the op. The hump hose and angle of the pic make it hard to see the alignment issue. I have a 1pc with regular transition hose (no hump) and you can definitely tell that it's off. Since the pipe bolts directly to the frame, adjusting the coupler doesn't do much. I'll take pics of mine tomorrow night and post up.
EvoXAddict
Mar 24, 2012 11:59 AM
akemi27
Feb 11, 2011 08:44 AM
5harkology
Jul 16, 2009 10:34 PM
akemi27
Aug 10, 2008 04:52 PM
donmeca2020
Mar 18, 2007 08:41 AM
