ATTN: BUSCHUR *Dipstick Retainer?*
Old Jul 19, 2009 | 11:25 PM
flyguycfi's Avatar
Just wondering if you all plan on making an oil dipstick retainer like you have for the 8/9. Since we don't have the ring on the dipstick I don't think we can use the same one.
I got oil all over the engine bay once now I don't want it to ever happen again.
Old Jul 20, 2009 | 07:51 AM
slo4g63's Avatar
Damn, what happened?
Old Jul 20, 2009 | 08:28 AM
Mad_SB's Avatar
too much pressure in the crank case causing the dipstick to pop out under boost and oil to hose down the underhood area.
Old Jul 20, 2009 | 08:34 AM
Mad_SB's Avatar
I know that I have no idea what your setup is or what steps you have already taken to alleviate the excessive crank case pressure so if you already know this then please don't take offense....
Dipstick is popping out due to excessive pressure build up in the crank case. How much boost are you running? What changes have you made to the crank case vent setup? Are you running an open breather?
Better approach would be to try and address the problem (excessive crank case pressure) rather than the symptom.
Old Jul 20, 2009 | 08:41 AM
Jrod@Buschur's Avatar
We'll look into it.
I'll mention this to David to see what his input is on the topic.
Old Jul 21, 2009 | 12:23 AM
flyguycfi's Avatar
It happens all the time with the 4G63 guys. I'm running 25PSI and the PCV vent, I think is what it's called, was kinked and may have contributed to the oil spewing out.
I'm got an oil catch can just to be safe and plan on installing it ASAP!
Originally Posted by Jrod@Buschur
We'll look into it.
Thanks! BTW I got your crossflow cat-back and it is PERFECT! Thanks!
Old Jul 21, 2009 | 03:27 AM
Mad_SB's Avatar
I would imagine the kink is what caused the dip stick to pop out. I run 25psi every day and have never once had the stick pop out. I do still have the valve cover vent plumbed back into the intake pipe, which will pull a vacuum most of the time. With the boost your running I don't see any reason why you would be popping the dip stick other than venting the valve cover to atmosphere or a kink / blockage in the vent line.
Catch can won't help unless you get a vacuum source on one side of it, like the intake pipe.
Point is excessive crank case pressure will among other thing cost you some power because the pistons are having to fight against the pressure.
snowpro4g63
Nov 29, 2016 09:57 AM
TxFAkuma
May 15, 2016 03:03 PM
AJsGenerX
16
Sep 8, 2012 06:43 PM
sabastian458
Dec 11, 2008 12:31 PM
VTEC Killer
13
Mar 14, 2005 07:47 PM
