Will HFC pass emissions?
Old Jul 29, 2009 | 06:12 PM
simons's Avatar
I have an UR test pipe on my car living in SC which doesn't do emissions testing. I may be moving to PA which does require it. If I put on an UR HFC, will my car pass emissions testing? And has anyone confirmed this with an annual inspection?
Old Jul 29, 2009 | 06:25 PM
LagginTimes's Avatar
While I was living in PA with my old Evo IX, I had a Mil-Spec 100 cell cat. I went to the dealership to get inspections annually. They do OBD-II testing, so as long as there's no CEL (and I'm guessing they might do a visual check), you should pass.
Old Jul 29, 2009 | 06:49 PM
J5isalive2's Avatar
exactly why I got a resonated test pipe..... Inspection is only visual and obdII..... those guys working the inspection station aren't gonna take a long enough look to realize my Resonator isn't a Cat
Old Jul 29, 2009 | 07:50 PM
xtmx's Avatar
Its true, the local mom and pop shop I used would never look under the car, (my old wrx was catless). A couple times the mechanics made comments on how bad the exhaust smell was, then the car would pass OBD-II.
Old Jul 30, 2009 | 12:15 AM
flyguycfi's Avatar
So back to the OP's original question.
Will a HFC pass emissions?
Old Jul 30, 2009 | 07:11 AM
DarwinX's Avatar
Though this is true, I question if a 100 count cat would pass the "sniffer" test.
My high-flow cat is a 300 count, and I haven't read of any 300 count cats failing the "sniffer" test.
Old Jul 30, 2009 | 07:22 AM
The majority of PA uses OBD-II in lieu of the sniffer test (it's usually one or the other), so the OP should be fine.
Old Jul 30, 2009 | 12:02 PM
simons's Avatar
So all they do is hook up the OBD-II sensor and that's it? I was told that some states turn your car on and hold something in the exhaust stream. "Sniff" test as you guys call it.
I have an Ultimate Racing test pipe and no CEL, ever. But if you look under the car, you can obviously tell there's no cat on the car. I guess I could pick up a HFC from Ultimate Racing. I wouldn't want to fail the inspection. Plus a HFC is better than the stock cat anyday.
Old Jul 31, 2009 | 11:31 AM
Spazpilot's Avatar
This all depends on your state. If you lived in Cali no it would not pass. They state that the factory cat can not be replace with any other cat then the original. Texas on the other hand is like some of the other guys have posted. No CEL and a quick visual (if that) and your good to go.
Old Jul 31, 2009 | 12:39 PM
DVDee's Avatar
I live in PA and they did both the sniffer and obdII test on mine.
Old Jul 31, 2009 | 01:20 PM
GGEvoX's Avatar
You should almost definitely be fine with a HFC. I live in PA and I ran my catless WRX for 4 yrs and never once had a problem. My X is catless also and I have not had any problems. As long as there is no CEL you are good to go. Either way if they do look under the car and you have a HFC you should be fine.
Old Jul 31, 2009 | 04:24 PM
simons's Avatar
Invidia's catted downpipe is 100 cell count. I hope that would pass the sniffer test. Either Invidia or Perrin. I don't want to chance it with my test pipe. In case they look under the car.
Old Jul 31, 2009 | 04:58 PM
RaysEvoX's Avatar
I live in PA. I had a Invidia Catted Downpipe on my WRX, I have had both test ran on it and it never failed. You will be fine with a HFC on your car.
03OZstocker
Mar 9, 2016 06:03 PM
marylandevo8
32
Apr 7, 2013 08:13 AM
Viegasjuice
Mar 10, 2013 04:43 PM
mx597turbo
Nov 25, 2011 09:46 AM
PedroMartinez
17
Sep 30, 2008 09:19 PM
