threw a c161e code
Old Jul 30, 2009 | 08:03 PM
sgtpruitt's Avatar
threw a c161e code
The AP says it something with the ACD, but I cannot find any info on this.
Just did a clutch install, didn't disconnect the t case from the acd so I have no clue.
edit: ok I found the code in the SM. It's the awc pump. WTF could be the problem with the awc pump?
Old Jul 30, 2009 | 08:40 PM
sgtpruitt's Avatar
OK I found a thread about the pump. There was no resolution. Apparently the pumps have been going out. My car is highly modded and I just did a clutch replacement. I think I am screwed with the warranty but I can give it a try.
Old Jul 31, 2009 | 03:26 AM
robh's Avatar
did you take the transfer case out to do the clutch
if you did the only way to bleed the transfer case is with the mut from mitsu
DTC SET CONDITIONS
The code is set when the electric pump operation signal is output from AWC-ECU, and when the AWC pressure sensor signal is not reached the specified pressure after the specified time has elapsed.
PROBABLE CAUSES
•Fluid malfunction (low fluid level)
•AWC pressure sensor malfunction
•Electric pump relay malfunction
•Hydraulic unit malfunction
•Electric pump malfunction
•Damaged harness wires and connectors
•Malfunction of AWC-ECU
Old Aug 7, 2010 | 09:26 AM
m3typer's Avatar
Same thing just happened to me after I had my clutch installed yesterday. Anyone else run into this during a clutch install? It's too coincidental the pump went out the same time I swapped my clutch. Did my mechanic forget a step? I even had him put fresh diaqueen gear oil in the diff and TC. Anyone?
Old Sep 26, 2010 | 07:44 AM
Mendo's Avatar
Anyone know more about the subject???
My car has been whining like crazy in the last few months. Last week dealer told me they fixed the wiring to the pump; but last night it whined again, then stopped, and threw this code. ARGGHH!!
Old Sep 27, 2010 | 11:07 AM
Nsomniac's Avatar
EvoM Administrator
I'm having the same problem after a clutch install and diff fluid change. Took it to the service dept. They power bled it, and the problem went away for a week until this weekend. The first time my car slid (autocross), the code is back.
Old Sep 27, 2010 | 11:34 AM
Mendo's Avatar
Is anyone that is experiencing this code also getting a "whine" from their pump unit?
adam8756
Aug 16, 2015 09:23 AM
Heliart
14
Oct 19, 2012 02:05 PM
xop32
Jul 17, 2012 03:15 PM
RalliAaron
Jun 26, 2012 06:29 PM
Mendo
Nov 1, 2010 09:14 AM
