best turbo options for 0-60
my .2c
Carlos
Yes, I'm quoting my own post.
OP, are you against running water/meth injection? It's a fantastic mod for 0-60. Check out Archiebabie's car in the link below. Massive torque!
SUPER STREET SETUP:
Basic Bolt Ons
Meth/Water Injection on the stock turbo
THEN (if you aren't satisfied)
Cams
You will definitely need a clutch with greater holding power.
Check out some numbers here:
https://www.evolutionm.net/forums/ev...check-out.html
Basic Bolt Ons
Cams
0-60?
I would go with a smaller turbo (faster spool), some cams, a larger displacement motor, maybe even change your gear ratios around if a fast 0-60 is your goal.
I'm with you. I was just trying to give some food for thought for getting the best 0-60 for the money. I was just trying to relate (adimittedly very poorly) that the bolt on's will be very impressive compared to stock, and before doing those, it would be hard for me to go straight to a bigger turbo which may make 0-60 worse. I hated my car's performance when it was stock (both weeks of it). Sorry for not being clear...
LovingLancer
10
Mar 22, 2013 09:47 AM
David Buschur
Mar 14, 2008 10:49 AM
Thanks!
