Clutch or turbo problmes, help please.
Old Sep 6, 2009 | 03:38 PM
jeangtd's Avatar
Originally Posted by max4rw
no! the way your describing the behavior of your car is exactly what thousands of other people have also experienced and described on this fourm including me! it sounds like it is 99.9% your clutch, as for a new one... if your short on cash act is good, if your a baller get a twin disk exedy...im sure searching will help alot with helping you decide what clutch you need Good luck!
did the ams master cylinder kit ever fix the problem of them breaking with the satge two exedy. other than clutch and fluids, what else do i need to change the clutch?
i can still drive the car it just slips under heavy load conditions.how long till it dies on me?
Old Sep 6, 2009 | 03:55 PM
jeangtd's Avatar
Originally Posted by evolvedx
4 launches is plenty enough on a stock X clutch. Evos eat stock clutches. If you're really going to stop modding at 100whp over stock, than an ACT will do you just fine.
but are the savings worth it? a nice clutch from exedy will outlast an act right? so id better put something very good in so i dont have to change it as often.
Old Sep 6, 2009 | 05:33 PM
max4rw's Avatar
im not sure on the cylinder kit fix thing cause i drive an evo 8 but if you search around on here im sure you will find an answer the search button is very friendly, u need everything you said and look in the evo 10 how to's on this form and there should be a step by step right up on how to change out your clutch and tools needed good luck!!
Old Sep 6, 2009 | 07:14 PM
jeangtd's Avatar
How different is the clutch setup in a regular lancer and the evo x? im thinking of getting the parts and have a mitsubishi dealer install
Old Sep 8, 2009 | 06:50 AM
ajithsilva's Avatar
ok si i go into first gear and have the rpm's at about 3000 and slip into second (this is normal everyday driving) then i need to accelerate some more so i put about 80% of throttle and the rpms just build up to 4k's and all f a sudden the power kicks in, It's like I depressed the clutch accelerated and then let of the clutch again, it happens through all the gears, the funny thing is that i launched my car form first to fourth and it didnt happen, its not like something that happens only sometimes, it happens everytime, sometimes it just doesn't happen. its an evo x with 5000miles gsr. downpipe, highflow cat, k&n drop in and accesport, i have launched it 4 times. already put the stock map on and still the same thing. do you think if air gt in the system it will cause this? or is my clutch gone?
thank's a lot
I had the same problem and just last week by clutch burnt..It sucks and all these times I thought it was because I installed the down pipe back exhaust. I still dont know how it could affect the RPM jumps like that in a low speed or from a complete stop. Anyways I am trying to get a decent after market clutch since the OEM clutch coudn't even last 2 years...sucks sucks sucks....
Old Sep 8, 2009 | 06:52 AM
ajithsilva's Avatar
Thanks for the input...I just burnt my OEM clutch and in process of looking for an aftermarket durable clutch.
Thanks guys!!!
Old Sep 8, 2009 | 06:56 AM
evodrivesme's Avatar
take out he accessport and take it back to the dealer.
mikebuff35
10
Feb 22, 2016 12:11 PM
JDM.Spec
Sep 11, 2015 04:17 PM
LtownEvo
11
Aug 13, 2012 07:11 AM
kamakazy_kid
May 2, 2012 02:01 AM
LeeC
Apr 17, 2010 10:00 AM
