ATC Clutch Question...
Old Sep 9, 2009 | 06:40 PM
Jfgad's Avatar
Question ATC Clutch Question...
Hi guys, to make a long story short, my OEM clutch is burned... after 5000 KM... so, mitsu don't want to put it under warenty beacause the car make too much power lol !
so i went for the ACT clutch :
http://www.vividracing.com/catalog/p...udl584b3tc0cr6
Is there anything i should know ? should i change the master cylinder as well ? i'm curently making about 325 WHP and don't plan to go over 400 WHP...
( curently running stage 1 map with AEM intake and 91 octane GSR USDM )
plan to run stage 2 as soon as i can afford the turboback....
any help with comments and suggestions would be appreciate !
Old Sep 9, 2009 | 06:59 PM
dragon831's Avatar
Myself and a friend of mine are running the act hd clutch. The pedal is just a tad stiffer than stock. I'm at 330hp 375tq and it's holding up just fine. Others might recommend a stronger clutch but if you're don't plan on making too much power im sure you'll be fine. Everyone will recommend (my self included) changing out the cylinder or at least getting the ams ring though..... i've yet to see one person with an act HD clutch brake the cylinder. I'm not saying it cant happen but the HD clutch only slightly increases the pressure.
Old Sep 9, 2009 | 07:29 PM
Jfgad's Avatar
thanks dragon ! i must admit after making a research on this forum about this, i must say i wa afraid it would be more problems... but no, i don't want to do to much power and never did and never will launch this car...
Old Sep 9, 2009 | 07:31 PM
High_PSI's Avatar
I have the XTSS, IMHO it is better then the HDSS which I had on my VIII. Pedal is easy to get used to but man it grabs gobs.
Old Sep 9, 2009 | 07:42 PM
Jfgad's Avatar
ok
Old Sep 9, 2009 | 09:22 PM
sne2040's Avatar
If you never launched the car and are only running Stage 1, how the hell did you burn through your clutch at only 3k miles?
I'm at 17k miles with a ton more power than Stage 1 and still on stocker.
Old Sep 10, 2009 | 07:41 AM
Jfgad's Avatar
Yeah, i know... done a bit of drifting, never launched and feel i never been hard with the clutch... but this oem clutch is the weak point of what is going to be a ****ing nice car with the new after market clutch...
maybe i drove it more agressive then you... but as i said, i've never been hard on the clutch...
Old Sep 10, 2009 | 08:35 AM
Guru's Avatar
my clutch was dying already at 15,000 miles and I RARELY launch the car. Took it out and the disc was almost gone. Keep in mind have FP Red and supporting mods so that didn't help with the wear.
Old Sep 10, 2009 | 02:58 PM
Jfgad's Avatar
ok but you realize 15K MILES is nothig compared to my 5000 KILOMETERS ( 3100 MILES )...
Old Sep 10, 2009 | 09:43 PM
sne2040's Avatar
***delete***
CJK
34
Apr 1, 2017 05:24 PM
2006GSR
Apr 8, 2016 07:46 PM
Dalastbmills
Lancer Tranny/Drivetrain Tech
Jun 11, 2012 08:18 AM
subi_killer8
11
May 6, 2011 02:13 PM
El Niņo
15
Feb 22, 2006 04:21 AM
