To do a VTA catch can or a sealed one on a 800+whp Evo?
Hey guys.
My curent catch can setup is 2 12am lines of the valve cover to a baffled VTA catch can. I have the option of getting a new catch can built and can't make up my mind to do a sealed one and have it get sucked out by exhuast or vent it to atmosphere? Car currently makes 771 awhp on 35 psi and plans to turn it up past 40. It's a 2.4 with a 6765 and all supporting mods to make 900+.
Thanks
Thanks
It is being switched to a Forward Facing Setup once i get the new manifold with a full exhaust out the back.
i have smelled it a few times when the wind was blowing just the right direction and i had the windows open and it was not a pleasant smell.
<a href="http://photobucket.com/" target="_blank"><img src="http://i235.photobucket.com/albums/ee30/igorka_91/IMG_5329_zpsfngbnb5s.jpg" border="0" alt=" photo IMG_5329_zpsfngbnb5s.jpg"/></a>
Need help for rear valve cover catch can setup using 10 AN fitting
Would you mind chiming in on a recommendation?
Im shopping for a dual catch can kit setup
as far as the front intake side of the valve cover I have a 6 AN fitting and will run that line to one port of the catch can and run the second line from the catch can to the intake...
for the rear of the valve cover I have a 10 an fitting... How should this be done I know the first line of course runs from the valve cover to the catch can but for the secondary port what should I do? block off the intake manifold port? and dump the secondary line to the ground or is there another option? on speaking for the rear valve cover
xRoguex
26
Mar 25, 2018 01:51 PM
roni4g63
Dec 17, 2016 08:54 PM
[WTB] WTB: Sealed catch can
mattyboost
Jun 8, 2014 07:59 PM
