AWC ECU Reprograming campaign
Old Sep 24, 2009 | 07:32 AM
stokEd's Avatar
Originally Posted by Brokenevo
man the X is having some serious issues
Not really. You're being dramatic. I have the original hood latch and my car doesn't catch fire every time I drive. And I've driven dozens of times in the snow down to -8* F, and at elevations of 11,000ft plus without any problems from the S-AWC or the car in general.
Aren't there WRX/STi guys on NASIOC guys with '08-'09s having whole motors replaced due to problems from the factory? Maybe they could use your pessimism over there.
Old Sep 24, 2009 | 08:08 AM
mike100's Avatar
not cold enough..ask the guys in Edmonton about the AYC diff motor problem when you get to -30-40C. I'd like the update just in case.
Old Sep 24, 2009 | 02:00 PM
Drew84's Avatar
With global warming, does anybody really need the recall?
Mine is done, that was quick and painless. The fuel line is same design as the old one, they put a new one in just in case that one was damaged and added two brackets. Once you reinstall the plastic cover. You would never know anything was different. The AWC reprogram takes less than 5 mins.
Old Sep 24, 2009 | 04:48 PM
sonicrx's Avatar
again i know this was asked ,but since you had it done will it mess with my ecutek flash and tune?
Old Sep 24, 2009 | 06:30 PM
MikeAce's Avatar
Same thing happened to me in Alaska.
Originally Posted by diabolyk
wow i thought i was bad tripping last winter... it was like -30celsius out here... i start the car and when switching to SNOW mode, S-AWC service required popped up, and the car drove like crap, and the service manager at dealership told me i was on crack... yeah right. looks like a 3rd recall for my evo... sigh
Old Sep 24, 2009 | 09:30 PM
finnns2000's Avatar
so are all dealers aware of the fuel and awc issues?
Old Sep 24, 2009 | 09:34 PM
Clipse3GT's Avatar
Probably most will know by Sept. 29/30th.
Old Sep 24, 2009 | 09:54 PM
finnns2000's Avatar
^ Got it. More trips to the dealer, nice...
Old Sep 25, 2009 | 05:49 AM
mdc's Avatar
mdc
I went to the dealer yesterday and my fuel line recall appeared on the computer but nothing about the AWC or hood latch. I even specifically asked about them but they said we have no information about that.
Old Sep 26, 2009 | 09:09 AM
Drew84's Avatar
No, that is not the same ECU as the Engine ECU. The AWC system has it's own ECU. That is what is being reprogrammed.
The AWC system should also come up on the Super Screen, but it also only applies to cars built within a certain date, vin range and sold within a certain geographical area. The hood latch may have been performed before you bought it or already updated at the factory.
Old Sep 26, 2009 | 09:38 PM
poof101's Avatar
Bell Mitsubishi reflashed my AWC this week when i went in for my first service...they also ordered my fuel rail.
Old Sep 26, 2009 | 09:59 PM
xPRimNT's Avatar
Such as myself
I had my ACD pump replaced. 7+ hours of labor and a $4000 CAD part. Quite the bill at the end of it, first time I've ever had to use a warranty.
It noticeably "went" on a -35˚C day. Then the Service Required light came on and stayed on until I finally got the dealer to replace it almost 5 months later.
I'll take the reflash, thank you very much.
Old Sep 28, 2009 | 02:14 PM
solipsism's Avatar
Originally Posted by xPRimNT
Such as myself
+1 on that. Mine went out in November (-30˚C) and the service required light was on until May the next year when the pump was replaced.
I've been wondering what was going to happen this winter since the pump and fluid is the same. I hope this is a fix for it although I thought it was a mechanical fluid problem, not something that could be solved by programming.
Old Sep 28, 2009 | 03:47 PM
unkle bebot's Avatar
called south coast about the AWC ECU... "heard about it.. but nothing came in yet" im assuming its details to what should be done. also he said to call 888-mitsu-20 and have ur VIN num ready and they will give u details.. good luck everyone.
Old Sep 28, 2009 | 04:14 PM
CatalystGod's Avatar
Not likely. AWC has a separate Computer/control-unit that communicates with the main ECU over the CAN bus I believe, unless somebody's gonna come along and tell me I'm on crack and that I'm talking outta my a$$ !
