Anyone bought a new bare block from Mitsu?
Old Oct 16, 2009 | 10:41 AM
DRAG's Avatar
I am getting ready to order my block and was curious if anyone has purchased the bare block. If you have, how were the cylinders finished out of the box? Are they honed for a stock bore piston or is there enough there where I can do my own for an 86mm piston install?
There isn't a lot of info on Mitsu replacement parts
Thanks in advance.
Old Oct 16, 2009 | 10:51 AM
UT_EvoX's Avatar
Will be honed/plateaued for the stock piston application, but will provide plenty of material for another hone to get the proper piston-to-wall clearance for your new forged stock-size pistons.
That is if you are planning on running additional wall clearance for more boost. If not, it's pretty much a mic the pistons, bore check the cylinders, make sure clearances are as desired, and slap them in, job.
Old Oct 16, 2009 | 10:55 AM
DRAG's Avatar
Thats all I needed to know. Thanks for the quick reply.
Old Oct 16, 2009 | 12:14 PM
flyboytb's Avatar
I dont know how much the oe block will cost you but this may be an option....
http://www.amsperformance.com/cart/A...mance.com.html
Old Oct 17, 2009 | 10:40 AM
Xcited's Avatar
I just bought an oem block. List price is $1850.42 USD. I'll let you know the what the cylinders are finished like when I receive it next week. Also, for $3300 USD, you can buy a complete shortblock assembly. The part # for the complete shortblock is 1000B021.
Old Oct 17, 2009 | 12:55 PM
proracer718's Avatar
I just bought an OEM short block which had the pistons and rods and crank in it and everything was basically ready to go. I used the other parts needed off of my old one and everything is ready and good to go.
Old Oct 17, 2009 | 01:02 PM
AWD Motorsports's Avatar
This option still requires a good core..
Mike
Old Oct 19, 2009 | 03:33 PM
EvilEvo9MR's Avatar
Buschurs has a stage 3 shortblock for the Evo X! Just another option for ya maybe?
https://secure.buschurracing.com/cat...oducts_id=1426
Old Oct 20, 2009 | 08:26 AM
DRAG's Avatar
Its too bad you already bought that, because you got rolled! MSRP isn't even that high.
https://www.mitsubishiparts.com/oe_parts_catalog.html
Complete Short Block - $2280.60
Bare Block - $1268.89
Old Oct 22, 2009 | 07:22 AM
Xcited's Avatar
Have you ordered anything from them?
Old Oct 22, 2009 | 07:37 AM
blueshark123's Avatar
Why not find a shortblock from a totaled car?
Old Oct 22, 2009 | 07:47 AM
DRAG's Avatar
I found a couple motors through LKQ and they wanted $5000 - 6500 and will not separate parts. New is cheaper and easier, and you always run the risk of cracked crap with crashed cars.
I bought a new assembled shortblock. It is not 100% complete with oil pump and pan...it has just crank, rods, and pistons. Decided to do that instead of building it and I stuck the extra couple grand in my daughter's piggy bank
Old Oct 22, 2009 | 07:48 AM
DRAG's Avatar
I bought from a local dealer but did not pay more than that.
Old Oct 22, 2009 | 08:12 AM
Xcited's Avatar
So, you paid $2200 for the shortblock from a local dealer?
Panchikis
Apr 2, 2016 04:07 PM
Blackened Sky
Oct 15, 2015 10:52 AM
Sideck
Feb 13, 2015 07:06 PM
blackgsx01
Oct 2, 2014 04:37 AM
NOMIEZVR4
Jul 30, 2014 12:28 PM
