WOT engine cut out?
Old Oct 28, 2009 | 03:57 PM
  #31
LVSBB6's Avatar
Could be overboosting or misfiring.
Old Oct 29, 2009 | 10:28 AM
  #32
►EvolutionX◄'s Avatar
If I was overboosting I would throw a code correct? My car backfires like crazy when I let off the throttle, which could hint to misfiring, I really should pull those plugs, but I am a little tied up with school and stuff right now. I'm installing a boost gauge in about a week so I'll check on the peak of boost. When I got my car tuned I did a few pulls on the way home and noticed a loud pstt noise at high boost levels, and I checked my I/C piping and the LICP was loose, it could be possible that it was loose during the tune and therefore my tuner tuned the boost up higher to account for the leak, and now it is overboosting. I wont know untill next week, I will pull my plugs, and check the boost. I'll keep you guys updated.
Old Oct 31, 2009 | 03:34 PM
  #33
EvoXAdam's Avatar
what plugs are you using? and does anyone know if NGK makes plugs for the GSR yet?
Old Oct 31, 2009 | 04:00 PM
  #34
PlayinWithFire's Avatar
If it was a hesitation and then continued I would swap out the fuel pump relay. Sounds like what was happening to me.
https://www.evolutionm.net/forums/ev...itsubishi.html
Old Oct 31, 2009 | 04:41 PM
  #35
xtmx's Avatar
I was thinking the same thing. This is what the local evo guru told me when I asked about the relay "they run into a lean miss, you would feel it ..kinda like it is running out of gas...."
Old Oct 31, 2009 | 05:57 PM
  #36
yea i noticed mine during a tune. When I punched it it hesitated like the clutch was slipping but there was no increase in RPMs. My first thought was spark plugs and I replaced them, but then when the issue was still apparent I replaced the relay and all was good in the hood (or under the hood!)
Pick it up if you have 20 bucks to spare. There is a how to on checking the functionality of your current one if you are hesitant to swap it out without a valid cause.
https://www.evolutionm.net/forums/ev...ay-1-test.html
►EvolutionX◄
Apr 28, 2013 09:27 PM
►EvolutionX◄
Dec 24, 2011 02:17 AM
►EvolutionX◄
Nov 13, 2011 06:20 AM
►EvolutionX◄
Evo X Dyno Results
16
Nov 9, 2009 06:46 PM
►EvolutionX◄
Oct 15, 2009 07:05 PM
