Sponsored by:
Sponsored by: CARiD
Gauge illumation question
Old Sep 9, 2009 | 05:55 PM
►EvolutionX◄'s Avatar
Ok well up to this point I am yet to see someone wire their gauges to the stock cluster so that they dim when the stock gauges are dimmed. (AEM gauges come with a gray wire that Is meant to be wired into your stock cluster so that they dim when you press your dimmer button) Is it because this is a very difficult process? Or have people done this and I just have missed it? Any Advice/PICTURES/help is greatly appriciated.
Old Sep 9, 2009 | 06:00 PM
Silver06evo9mr's Avatar
im sure its easy jjust gotta find right wire to tap into for power. but pointless if u ask me..
Old Sep 11, 2009 | 11:20 PM
jk68x3's Avatar
assisted in installing some gauges in an srt4 neon and opted not to use the dimmer because you couldnt see the gauges during the day (cheep gauges) so i would find an easy way to test them to see what u think.
Old Sep 11, 2009 | 11:22 PM
Well the Gauges are AEM Analog gauges, so I dont think they are cheap, and my wallet agrees ... anyways, I will probably just not use the dimmer wire unless anyone can for sure tell me where to run it.
Old Sep 12, 2009 | 09:01 AM
EndlessRed's Avatar
green-white wire behind the ASC switch. i posted this in the gauge install thread, post #95 https://www.evolutionm.net/forums/7011724-post95.html
Old Sep 12, 2009 | 03:42 PM
Thanks Much , May I ask how in the world you figured this one out?
Old Sep 12, 2009 | 04:19 PM
EndlessRed's Avatar
visual inspection. both the manual adjuster and the asc switch have illumination. the only wires that are similar are grounds and the illumination wire. figuring out what the negative wire is, is standard issue. then i'm just left with the positive illumination wire.
Old Sep 12, 2009 | 04:24 PM
llvllattp's Avatar
i had a person put led lights on my cluster this weekend...hes located in socal 2!
might cluster was dim before while my prosport gauges were really bright
so now after the LED they match perfectly now
Old Sep 14, 2009 | 11:37 PM
*UPDATE* For All you who are using an illumination wire for your gauges, tapping the green/white wire behind your asc switch will cause your gauges to illuminate more brilliantly when your lights are turned on, However, this wire does not dim your gauges when your dimmer button is pushed below your gauge cluster. (However this still does its job by making your gauges brighter at night, and I settled for it as it does suffice for the functionality of the wire)... Will post a how-to on Illuminating gauges sometime soon.
Old Mar 11, 2013 | 08:36 AM
dasmikechen's Avatar
I have been scouring for a wire to use for AEM gauge illumination. So many people are point to on/off wires that actually work in the reverse way that AEM wants. AEM should have dim (low volt) during night time with headlights on and should be bright during daytime with head lights off (high volt). At night, why would you want your gauges blinding you?
I guess everyone just leaves the gauge at full 12V brightness, but I have to imagine there is somewhere to tap on the wires that changes in voltage based on dimming the lights!
Old Apr 22, 2013 | 03:46 PM
YoLa's Avatar
easy solution for your problem - 34$ Dimmer made by autometer sold at summit or amazon. This can also be used if like myself, you are running Autometer C2s and they are obscenely bright or if you don't like dimming your speedo and such to blackout in order to dim the gauges. It's a 5 minute install!
Old Apr 28, 2013 | 09:27 PM
I installed a switch in the blank cover spot left of the steering wheel, but... this is not as clean : /
ZWingerRyRy
Evo X How Tos / Installations
267
Apr 22, 2020 04:26 AM
fjm9898
Jun 20, 2016 10:12 AM
McDougal
Feb 22, 2012 09:49 AM
pignosesr
Dec 18, 2011 04:56 AM
justin.AZ
Lancer Troubleshooting
Oct 28, 2009 07:59 PM
