IC pipes + turbo inlet require tune ?
Old Nov 19, 2009 | 03:12 AM
skyseer's Avatar
My car is 100% stock, including exhaust and air filter. I plan to install IC piping kit, turbo inlet hose and bypass pipe. Do I need a tune after install. Or is it 100% safe to drive my car untuned ?
Old Nov 19, 2009 | 04:45 AM
GasHead's Avatar
No a tune is not required because the car is way to rich from the factory.
Old Nov 19, 2009 | 05:48 AM
skyseer's Avatar
Hmm ... Do ic pipes and turbo inlet really lean mixture ? I mean ... air filter is still stock.
Old Nov 19, 2009 | 05:52 AM
blkmkIII's Avatar
why wouldnt you just get a tune/flash instead of that crap which shows little to zero gains.
Old Nov 19, 2009 | 05:57 AM
skyseer's Avatar
I will get a tune after exhaust and intake. For now I don't want to mess with warranty.
Old Nov 19, 2009 | 06:01 AM
Hiboost's Avatar
That upgrade should just reduce intake restrictions for the most part and the increased flow past the air sensor should be matched with the appropriate fuel. If you shift into higher load % on the maps sigificantly then the tune could change, typically the stock maps get richer with lower timing the higher load that is reached which tends to squash gains somewhat until tuned properly.
mithrandir7533
Nov 24, 2020 12:40 AM
TopLevelPerformance
Jul 5, 2014 12:54 AM
hamiltonj2w1
Nov 1, 2012 05:54 AM
blklbl24
Feb 8, 2012 07:59 AM
neveronlineten
12
May 6, 2009 08:33 PM
