Best BPV
Old Nov 22, 2009 | 09:39 AM
chriswolf81's Avatar
Best BPV
What aftermarket BOV's is everybody haing success with?
I know the stocker is fine, but I want to upgrade turbo and probably E-85.
Since I want to get the ETS I.C. kit, I am thinking of getting the Tial flange option.
Any experiences with the Tial BOV? Or other BOV's?
I'm going to go recirc only and don't want any problems.
Old Nov 22, 2009 | 10:26 AM
itznoraa's Avatar
do you mean BOV? if so, synapse makes a good BOV.
Old Nov 22, 2009 | 11:23 AM
I think there is small difference between the two. By Pass Valve/ Blow Off Valve.
I think it is the difference between recirculated and vented to atmosphere, but I could be wrong.
Old Nov 22, 2009 | 11:30 AM
itznoraa's Avatar
ah, i didnt know they had different names.
Old Nov 22, 2009 | 12:35 PM
mdevo84's Avatar
No you can recirc a Blow Off Valve also. I dont know why you would want to swite the stock Diverter Valve is good for your setup. No reason to switch at all unless you plan on running an insane amount of boost upwards of 35psi
Old Nov 22, 2009 | 01:13 PM
linjy2's Avatar
i have this and i needed cause my stocker started to not hold after 27psi
i ran mine as recirculated.
Old Nov 22, 2009 | 01:16 PM
Clipse3GT's Avatar
GFB Stealth FX, Tial Alpha Q, Synapse, etc... all of these are pretty good.
Old Nov 23, 2009 | 06:34 AM
murlo26's Avatar
Crush the stock one, that is what all the 9 guys do and GST has done already for the X. They are the same BPV as the 9's had so it should work fine.
That is what I am planning on doing when I put my red in. PS, it sucks having a new turbo and not having it in your car
Old Nov 23, 2009 | 10:22 AM
Clipse3GT's Avatar
I had mine crushed and it leaked at 26-27PSI. It is really luck of draw how much these valves hold. Each one is a bit different. Quality control....
Old Nov 23, 2009 | 11:18 AM
murlo26's Avatar
Hmmm, interesting. I think am going perrin when i change from stock if my stocker crushed wont handle my red. The Perrin supposedly holds 190psi So I guess we will see.
SeanM505
Oct 22, 2021 05:27 AM
MMMR0820
12
May 15, 2010 10:55 AM
Evo818
14
Apr 8, 2008 12:18 PM
ApexVIII
Nov 21, 2007 11:16 PM
rlazer5000
Jul 13, 2005 09:58 AM
