Rattleling when letting off gas
Ive been noticing a rattleling sound when you depress the gas on the higher gears, typically in 4th and 5th, i can hear it in the other gears but 4th and 5th seems to be the most present. Like if you were going 50mph and you let go of the gas and decel. It almost sounds like my s2000 when i put an ACT clutch in it and the clutch disk springs would rattle on decel. Im on stock clutch btw. If anyone of you guys are still on stock clutch and go drive your car with the windows up and music completely off, and see if this happens to you and let me know i would really be thankful. Any of you guys experiencing this?????
Remove Your exhaust manifold heat shield, then have a friend rev and let off the gas at idle... while you look at where your wategate actuator arm is attached to the turbo. If its remotely loose it will vibrate and rattle on decel.
Are you sure it is not the fluttering sound from an aftermarket intake, when you release the gas pedal below 0 psi boost? It sure sounds like it.
A list of mods would surely help. Have you done down pipe mod? if so, it could definitely be the heat shield.
Is it a 'harmless' rattling, or a sound like maybe some damage is occuring? My TC made a LOUD decel rattle for a while before it finally let go... It doesn't sound like that's the issue though especially is you've never messed with the TC fluid or the clutch.
NelloMorto
Nov 24, 2010 12:48 PM
