what determines and engines RPM max?
Old Dec 4, 2009 | 05:11 PM
  #31
palmerblock's Avatar
Originally Posted by mguerrero
Now back to the topic...Does anyone know the oil pressure that the X runs at and if its safe with high revving?
ill know this in a month after i put in a guage and redyno on a different turbo...
but im pretty sure someone else should have this info already...
Old Dec 5, 2009 | 10:40 AM
  #32
mguerrero's Avatar
Originally Posted by palmerblock
i had my open deck built motor in hondatas landspeed rsx making over 700hp with twin superchargers and it held up nicely...
revs to 9600 rpm and maintains a rpm of 8600-9600 over a minute and a half....
with that being said, the 4b11 is fine especiall since it has more bracing...
all this paranoia with a aluminum block should be thrown out the door especially seeing what hondas can do...
The aluminum block is the least of our worries. I think everyone is more worried with the semi open deck. The cylinders are the weak point if you'll be revving up to 9000 but the cylinders wont be aluminum, there's no way (of coarse im talking about if you have a built motor). i wanna know what the point of no return is with the cylinders.
Old Dec 5, 2009 | 02:56 PM
  #33
DRAG's Avatar
Lots of Honda guys have pushed big power on full open decks. I wouldn't worry about it unless you are running huge cylinder pressures.
CJBarker2
Jul 26, 2017 07:17 PM
av00va
13
Sep 1, 2013 07:26 AM
Paintabruh
Mar 7, 2012 10:52 PM
D-VO
20
Sep 30, 2010 09:24 PM
silverEVO8
11
Jun 9, 2007 04:26 PM
