blouch or fp red for evo x
Old Dec 20, 2009 | 10:34 PM
evokenny's Avatar
which turbo would you go with? im trying to make a decision on getting an upgraded turbo for my evo x and need a few recommendations..maybe other turbo options as well if you have a different turbo other than the blouch or fp red.
Old Dec 20, 2009 | 10:43 PM
delkat's Avatar
Data from the CBRD BBX stock frame turbo will be available soon. It flows more than the Blouch and has similare spool.
Old Dec 21, 2009 | 10:06 AM
criptballer's Avatar
Well I just installed my FP red yesterday and all I can say is that it's ****!
Old Dec 21, 2009 | 10:17 AM
Clark_Kent's Avatar
Neither.
Old Dec 21, 2009 | 10:20 AM
hotdog's Avatar
Originally Posted by Clark_Kent
Neither.
That. There's a lot of options out there now. If this was like... 4 months back, this would be a legit question
Old Dec 21, 2009 | 12:31 PM
MarkM's Avatar
why not a green??
Old Dec 21, 2009 | 12:44 PM
hotstix's Avatar
I went DOM 2.0
Full boost by 3400 RPM (25psi)
Pulls hard all the way to redline
380 whp on a conservative 91 oct. tune.
Old Dec 21, 2009 | 12:47 PM
meat_EVO's Avatar
red worked for me 25 psi, pump 93, 415 whp on dyno jet that puts a stock x at 240whp/.
Old Dec 21, 2009 | 12:50 PM
AlienEvoX's Avatar
id go with the DOM 2.0, to me its a better turbo than the FP Red, but I am also waiting on the stat #'s and results of the CBRD BBX stock frame turbo
Old Dec 21, 2009 | 12:56 PM
meat_EVO's Avatar
why is it better to you? Did it swallow?
Old Dec 21, 2009 | 02:14 PM
murlo26's Avatar
Red for race gas/e85, DOM for pump.
Old Dec 21, 2009 | 02:45 PM
hotstix's Avatar
For referance, this is what my DOM 2.0 did on the 91 octane DD map.
Gotta love that boost curve!
Old Dec 21, 2009 | 08:27 PM
HR2L's Avatar
well i recently had a Dom 2 installed and tunned on my 08 MR....500 miles later (today) were under the impression the turbo seals have gone bad (nothing like a ton of bluish white smoke coming out of your exhaust when you get on boost)...kinda of pissed. The car made great power (330whp on 91 @ GST Motorsports) all the way up until the Dom 2 took a dump. Should have waited for the CBRD turbo.
Old Dec 21, 2009 | 10:46 PM
spdracerut's Avatar
Might not necessarily be the turbo's fault. Might have been an issue with the oil feed line or something. Just a possibility.
Old Dec 21, 2009 | 11:07 PM
HR2L's Avatar
Care to elaborate on this possibility? If there was an issue with the oil feed line, it usually would be starving the turbo of oil. In my case the turbo is burning oil, not being starved of it. We checked (without removing the turbo physically) for oil leaks (thought that maybe it had become damaged and thats what was causing the burn, but when you burn directly through the exhaust its a bit hard to equate it) or bad oil feed line, didn't notice anything.
