Rexpeed o2 downpipe install & review *56k gtfo!!!!*
Old Aug 23, 2010 | 06:40 AM
  #31
tsitalon1's Avatar
Any updates from the 2 that purchased/installed these units?
I am looking for a cost effective o2/downpipe for my soon to come turbo swap.
Have these lasted throughout all the heat cycles? any cracking/exhaust leaks? anything weird at all?
Old Aug 23, 2010 | 08:32 AM
  #32
steven88's Avatar
mine has held up fine...and i have had at least two track days on them....i do have a front motor mount, which i heard helps prevent any stress on the DP
Old Aug 23, 2010 | 08:35 AM
  #33
tsitalon1's Avatar
Hmm.. thanks! Maybe I'll window weld my motor mount.
How many miles have you put on it now? You do DD right?
Old Aug 23, 2010 | 08:55 AM
  #34
steven88's Avatar
i have put about 7k miles since the install
Old Aug 23, 2010 | 03:31 PM
  #35
Maverickvf84's Avatar
Originally Posted by AutoMotoSports
Ask and you shall recieve
There is a great book by Corky bell called "Maximum boost" I highly recommend everyone interested in learning about turbocharged cars reads this.
In short you want the largest area possible near the turbocharger because of the exhaust gas temperature. When gasses leave the turbo they are at their hottest and the least dense. As they cool they will become more dense and take up less space. For this reason you can take an exhaust that starts out larger and slowly taper it down to flow more than one that starts out smaller but maintains that diameter throughout. This is because the gasses are cooling and becoming more dense as they flow downstream. The large bellmouth type opening in the AMS Widemouth downpipes are conducive for that hot air to cool easier and actually optimize flow. In short having a smaller section at the turbo exit flowing into that same diameter piping can cause the adverse back pressure effect. There is a reason why our pipe has such a great increase in power. Bigger is better behind the turbo
Again I highly recommend everyone pick up the book Maximum boost...its a GREAT read!
hope that helps
Eric
+1!!!!!!I love my AMS DP...and since I just added the Ultimate-Racing Resonated test pipe it twice as good!!!!!!I cam real close to buying the test pipe mini-muffler but lucky they had 1more a resonated test pipe available!I got super lucky and my X soundsa and feels GR8!!!!My waste gate flutter went away also!.This is my 1st turbo car and turbos are really interesting!!!I will look into that book!
Old Aug 23, 2010 | 04:23 PM
  #36
migs647's Avatar
hope that helps
Eric
Wow, my friend gave me this book on turbos a few years ago. I never really looked at it cause I've been very busy. I went to buy Maximum Boost on amazon, and noticed the cover looked familiar. Sure enough, same book. I better read it
Old Dec 15, 2011 | 11:33 AM
  #37
kmg_910's Avatar
any CELs with this dp/tp combo??? i also just purchased the exact same setup as the OP...
Old Dec 15, 2011 | 12:27 PM
  #38
WarmMilk's Avatar
DAMN IT! I have 56k... I really wanted to see this to...
Old Dec 15, 2011 | 02:49 PM
  #39
steven88's Avatar
no CELs...everything works great as long as you run the extender
Old Dec 15, 2011 | 04:46 PM
  #40
kmg_910's Avatar
nice! im excited to get it installed with my invidia n1 CBE...but i heard a vid from the evox bbq exhaust shoot out of a rexpeed dp with a SC TP and you could hear it rattling when he revved it..do you notice any sort of rattling or metal vibration at higher rpms?
Old Dec 15, 2011 | 06:01 PM
  #41
steven88's Avatar
i don't recall any sort of metal rattling in the higher RPMs...maybe just a TAD...but honestly, you can't complain too much because a test pipe does give a somewhat of a rattle tin can raspy noise...granted the ultimate racing mini muffler helped alot with the noise, but probably the SC TP just doesn't muffle out the rattle
Old Dec 15, 2011 | 06:50 PM
  #42
WarmMilk's Avatar
I have a test pipe and no rattle tin can raspy noise... stock downpipe though...
Darewood
39
May 5, 2013 07:07 PM
Kevin Troy
Mar 23, 2013 01:10 PM
Evo8
Apr 13, 2011 08:36 AM
Rexpeed
Aug 31, 2010 11:18 PM
