Fp red?
Old Apr 12, 2010 | 08:30 PM
JDMonster's Avatar
Fp red?
i have all the bolt on stuff and im consiudering a FP turbo before my AMS tune in may...... Do i need injectors and pump? thoughts? possible HP #'s?
all input welcome
Old Apr 12, 2010 | 08:34 PM
joshevo22's Avatar
You dont really need them but then buying the turbo would not be worth it at all.. Id say buy fuel pump and injectors and then get turbo. Thats what im doing!!! so you can support the turbo and run as much boost as you want and your #'s all depends on the dyno...
Old Apr 12, 2010 | 08:48 PM
healthynine's Avatar
have you looked at the CBRD BBX? I've read some not great things about the red on the X. I'd look at that turbo with a new fuel pump.
Old Apr 12, 2010 | 08:50 PM
hazdaddy's Avatar
what kind of numbers are you aiming for? what overall goals do you have for the car? some of the things that will effect the advice you'll be getting. I love my red though, getting tuned next week FINALLY! lol
Old Apr 12, 2010 | 08:52 PM
erald01's Avatar
a pump is a must, injectors not that needy but always a plus so you dont max out the stock ones. BUt if you are shooting for 350-400 your stock injectors should be fine
Old Apr 12, 2010 | 08:59 PM
EvoAJR's Avatar
you do need injectors at least 880's or 1000 cc and meth is a must if you want the red perform its full potential at least 30psi 500hp plus it all depends on driver/owner
Old Apr 12, 2010 | 09:01 PM
JDMonster's Avatar
I really just want it to be a fun fast daily car. Id love to see 400 Hp and drive it everyday. I have a MR to so im worried about the Trans. I have the AMS Trans cooler so hopefully that will help a bit.
Old Apr 13, 2010 | 06:38 AM
murlo26's Avatar
^Actually the FPred is better for the MR than the dom2 or the green. You want lag on the MR's. The less torque the better and the more lag = less torque.
Top end is fine for the MR, get the laggiest stock frame you can imo for the MR.
Old Apr 13, 2010 | 07:30 AM
talondex's Avatar
be on the safe side get a pump and injectors
Old Apr 13, 2010 | 09:53 AM
murlo26's Avatar
Originally Posted by spdracerut
Hotdog is correct, a laggy turbo is actually benefical on the MR to keep the torque down. Well, let me rephase, for some reason the 'tuners' do not limit the boost/torque of the faster spooling turbos as I think they should.
Anyways, a bigger turbo is just like a mechanical way to limit torque Once Garrett fixes their issue with the wastegate arm and valve, the 3076 is a good option. Or I suppose you could buy ATPs external wastegate downpipe to go with it like Hiboost.
I believe hotdog said the FPred was bad and I said it was good. Come on now, props needed
Old Apr 13, 2010 | 10:12 AM
mitsuorder's Avatar
Back on topic or more infraction points will be handed out.
Old Apr 13, 2010 | 03:03 PM
joedr's Avatar
EvoM Moderator
No more off topic comments!
Old Apr 13, 2010 | 10:16 PM
hazdaddy's Avatar
Im sure there are plenty of other options for you to get 400hp in a street car but in my experiences, the fp red is a great turbo to have on a daily driver. It's street friendly but when you want the power, u got it. Good luck with whatever you decide. keep us updated
Old Apr 15, 2010 | 08:05 AM
cpunlamd's Avatar
Bigger turbo requires a larger pump and injectors.
Next question..
pls1968
Jul 13, 2020 01:16 PM
djelliott978
14
Feb 5, 2020 04:26 PM
turbooutlaw1976
59
Sep 19, 2010 05:48 PM
dambikeracer
29
Jun 16, 2009 10:26 PM
FL_SilverEvo8
27
Apr 22, 2009 09:20 PM
