what spark plugs?
Old Jun 2, 2010 | 03:19 AM
IrvineXGSR's Avatar
i just changed out my plugs. after some research, i went ahead and stuck with the oem ones. oem ftw!
Old Jun 2, 2010 | 03:22 AM
boy36's Avatar
I used HKS M45XL-9 heat range,have 100 Hp plus and running well
Old Jun 2, 2010 | 09:35 AM
UT_EvoX's Avatar
Originally Posted by imdrew12
What about these?
Spark Plugs BRISK Silver Racing
http://www.perrinperformance.com/pro...ory=4&model=26
Do plugs actually make a difference?
I posted a bunch of input on these plugs above...
Originally Posted by .MM
are the brisk plugs colder than stock?
Read my post above. They come in both 1 heat range colder, and then 2 colder at a "10" NGK heat range (which is most certainly too cold for anything but a track car).
Originally Posted by jcdeng
factory sparks are good, if your car is stock... if your car is modded to 400whp and above, or new turbo, E85, then you need okadas
No... try running 24 psi of boost on a car with a crappy distributor ignition. That's when you need some coil upgrades. The stock COP system is more than adequate for probably anything you throw at the car. I'm thinking of several high-HP/track Evo X builds right now who have stock coils. Regapping plugs may be a necessity at that power level, but that should only be done with great care.
Old Jun 2, 2010 | 02:27 PM
bremboy's Avatar
Yeah same here. Great plugs.
Once I get turbo upgrades and such I'll go with NGK Racing...
Old Jun 3, 2010 | 07:53 AM
XRims's Avatar
I was wondering as well, but AMS recommended I remain OEM. I took their word for it.
Old Jun 3, 2010 | 08:07 PM
hyperviperx's Avatar
Yeah been reading alot about the OEM being sufficient
pcamara17
31
Mar 22, 2015 06:57 PM
Oracle1
Oct 1, 2011 01:07 PM
izabran
Dec 24, 2006 07:28 PM
EgoBuSTeR
Dec 1, 2003 01:53 PM
Fly-OZ
Lancer Engine Tech
Apr 26, 2002 08:18 AM
