Synapse Synchronic BOV
Old May 28, 2010 | 09:15 AM
  #46
murlo26's Avatar
Originally Posted by Synaptic Evo
Correct, the new generation of Synapse bov do not have port C.
Doesn't have it, or you mean it's integrated now?
Old May 28, 2010 | 09:19 AM
  #47
boostedwrx's Avatar
Its' integrated now. Basically its getting the boost source from the UICP now I believe, Devon correct me if I'm wrong. It responds a lot better though!
Old May 29, 2010 | 08:58 PM
  #48
kickin wing's Avatar
They block port C and it looks as if the drilled from port c into the pressure side of the valve.
Just installed mine tonight and I could not be happier. So smooth.
I wielded the aluminum flange to the bottom of my UICP (Evo 8)
Great Product
BTW I am using port B and A is VTA
Old Jan 14, 2014 | 12:53 PM
  #49
IRISHEVOX's Avatar
anyone do a VTA on the X yet?
Old Jan 14, 2014 | 08:21 PM
  #50
murlo26's Avatar
You are the first to ever think about doing it on the evo x.
Old Jan 15, 2014 | 08:08 AM
  #51
IRISHEVOX's Avatar
i want to see how it plays out...
Old Jan 30, 2014 | 06:13 AM
  #52
Laza's Avatar
Originally Posted by Evol21
Installed mine this weekend and it works great on an AMS setup and FP Red. It flutters a bit if your not on it or at half throttle but it works great and doens't bother me at all. Able to hold much more boost and sounds awesome.
I have one on my 2010 Ralliart, and with a SRI intake you can really hear the air swoosch nicely. I have tried adjusting the synapse spring tension, but I can't seem to find a spot where there would be no flutter. There's always some when I lift the throttle more or less gently...like a swoosch rat-tat-tat swoosch sound. It's not compressor surge, I got that when opening up port A (or B, can't remember which one it was), and the stock BOV actually does the same thing (it just wasn't audible with the stock air intake).
So I suppose this is OK, there's no bucking or any anomalous effects otherwise.
Old Jan 30, 2014 | 07:34 AM
  #53
IRISHEVOX's Avatar
Mine does the same.... but i just ran mine VTA, with the antistall kit... and it's sounds the same just louder
Squatch
Mar 16, 2017 10:04 PM
D Walk3r
Apr 19, 2016 06:01 AM
mygsx
Mar 18, 2016 06:21 AM
Justindc2
246
Aug 10, 2010 09:39 PM
Mishi9
Jun 12, 2010 11:06 PM
