injectors or fuel pump first?
Old Sep 6, 2010 | 09:46 AM
Guru's Avatar
stock pump is fine. I'm on stock pump and on a gt35r hta with jun 272 cams and dw1000cc injectors. Stock pump is pretty darn good. I ran out of MAF housing before running out of pump.
Old Sep 6, 2010 | 07:58 PM
scheides's Avatar
EvoM Moderator
Stock injectors and fuel pump (read that: 100% STOCK FUEL SYSTEM) supported my car with BBX, intake, UICP, testpipe, catback, and stock downpipe at 26psi. The car started to go lean close to 8000rpm but not dangerously so.
I would like to fanatically say that the stock fuel pump and injectors will 100% support any setup on the stock turbo, on pump gas. They may even do some amazing things on E85, but that's unofficial.
Old Nov 1, 2010 | 06:00 PM
JED_POLAND's Avatar
Thanks guys - it all proved to be correct.
Old Nov 1, 2010 | 07:23 PM
ssg_petty_210's Avatar
For the X, go with injectors. You will max your stock injectors out before your stock fuel pump cant put out anymore.
Old Nov 1, 2010 | 07:31 PM
JED_POLAND's Avatar
I'm on stock injectors right now with the turbine making maximum it can.
However I am going to install possibly FP Green - what injectors should I get?
DW 850 is enough?
Old Nov 1, 2010 | 07:33 PM
FIC 950's will do just fine for you man.
Old Nov 1, 2010 | 07:38 PM
JED_POLAND's Avatar
So the stocks are not an option?
Anything wrong with DW's 850?
Smartj90
May 1, 2012 03:29 PM
pacent
Jul 17, 2011 10:24 AM
Cmax
Jun 24, 2011 02:13 PM
ablan029
16
Jul 6, 2009 06:20 AM
