My Clutch Experiences on the X
Old May 13, 2010 | 05:24 AM
  #31
CatalystGod's Avatar
I thought his name was "Russel Peters", That dude is off the hook.
Anyways, you cannot go wrong with that combination, its been serving fine for me so far.
Old May 14, 2010 | 08:42 AM
  #32
Another update,
looks like my TWM SS is also shifting fine now. I installed it about 2 weeks before my clutch swap and I thought it made things significantly worse. Good thing I decided not to mouth off on TWM online. The Engine mount tightening seems to have fixed the isse with the shifter too. Damn, its amazing how much grief this mount issue caused me.
When I had the stock shifter with the rubber bushings, I think I wasn't seeing a problem because the rubber bushings allowed play in the shifter base to adjust to the Engine movement. Since I put on the metal bushings with the SS install, that flexibility was gone and the shifts became horrible under engine movement.
Old May 14, 2010 | 09:42 AM
  #33
tsitalon1's Avatar
Intresting, I've been thinking of "window welding" my front mount but haven't b/c I just can't see how this could help with the shifting. I know others have reported that stiffer mounts help with shifting but it's hard for me to believe.
I may still WindowWeld it, but I will never use poly mounts on a DD car again!
Old May 19, 2010 | 10:50 AM
  #34
Evo-KNA's Avatar
how much were the diff pins?
Old May 19, 2010 | 12:43 PM
  #35
you got PM.
Old May 21, 2010 | 10:04 AM
  #36
ETS Michael's Avatar
Nice Write Up!
Old May 21, 2010 | 10:58 AM
  #37
Thanks Michael. Thanks again for making sure I get everything on time.
Old Aug 4, 2010 | 02:10 PM
  #38
Just had to use this thread, thanks again for the write up!
CatalystGod
Evo X How Tos / Installations
20
Dec 12, 2016 01:36 AM
boostlogic
Apr 6, 2015 08:07 PM
mmartahus
Jan 10, 2009 12:53 PM
bboypuertoroc
ExtremeTurboSystems.com – WA
17
Jun 13, 2008 01:12 PM
bboypuertoroc
Nov 18, 2007 01:23 PM
