Crushing the BOV is easy and works!!
As soon as I read the title I was thinking about the old 1G DSM BOV days. 2G's came with that crappy plastic POS but the 1G BOV was a solid piece.
1st, it only will hold more psi if it is leaking which is a pretty good chance on most bov's. Also you need to tune for this mod remember, please don't do it without a tune.
2nd, I don't think Erkle wanted to make money off of this, he gave you a free idea that some people don't know you can do, wouldn't be something to sell.
Works sells a stockish unit for 269. Charge 75 for a crush and test (excluding core charges) and people might take you on.
Bad things can happen if you f-up your DV you know.
I never said he wanted to make a dime. I'm suggesting it may be a viable service for someone to offer. It just seems like a good idea?.
It isn't that hard to do
I crushed my ix bpv today down to where the nipple meets the larger portion of the bpv.... I had been holding about 22.5 to 22.3 psi at 7krpm, now I"m holding 23psi solid. So I gained a bit. Guess it wasn't leaking to much. BTW my peak is 27psi to about 5500rpm then tapering to 23 now. Had to retune my wastegate maps because after crushing I was overboosting from about 4krpm on. Was leaking a bit I suppose.
FS[West]: Evo 9 OEM BOV (not crushed)
evo.matt
Jul 7, 2014 04:36 PM
