Green or Red for 400whp on 93?
Yes youll need to lean on the car harder with pump to make 400+ and with that it doesn't leave much room for error when you get the bad tank of gas.. That happens A LOT more times then people know with pump..
the graphs from FP show:
Green spools by about 3500rpm
Red spools by about 4400rpm
problem is MIVEC plays a big part in spool, I think if you got max boost out of a Red by 4000rpm you would be pretty lucky...
Green can probably do 3300rpm...
happy to be proven wrong of course
Mike
Here you go...stock vs Fpred, both are on e85 so its a good comparo...
Also with using a 3 port, my tuner slows spool down on the top end to avoid overboosting, so I would say 30psi by 3700rpm is pretty damn good
Sorry that was my latest tune...here is one before, still on stock clutch tune vs. E85 stock turbo.
It loses about 700rpm's of spool.
hehebut still thats pretty good for Stock to Red
BUT 3200 on E85 seems a bit weak
I hit full spool on 92.5oct by about 2900rpm (in 4th) and E85 will only make it spool faster...so yeah 700 is probably about right...
I think the green os more for me, but i wouldnt make good power with it due to crappy fuel so ill just regret i got it, and the red, well.....I dont think i can get used to the extra lag, its bad enough the way it is and i am neve on the highway, mostlly city driving on my day to day
