To stroke or not to stroke
Old May 25, 2010 | 02:00 PM
  #31
chkmgnt59's Avatar
By bore out .5 i meant for 86.5 pistons. From my understanding, even with a hone of the stock block, on a mid-high mile engine, a new 86mm piston will not fit with the clearances to spec. At least not every time. Hence going slightly bigger and boring out a bit. But I may also be wrong, this is just from what one shop has told me. Hell, I hope I'm wrong so I can just drop in rods/pistons w/o removing the block from the car.
Old May 25, 2010 | 02:03 PM
  #32
murlo26's Avatar
That is the theory, typically on a newer engine you will have no problem dropping in stock sized pistons. However, when you get to the probably 10k marker and above and get some abuse on there it becomes a crapshoot.
Old May 25, 2010 | 02:44 PM
  #33
mlomker's Avatar
Buschur suggested to me that you're good up to 10k miles, as Dave mentioned. I did mine at 6k and I was pretty easy on the car during those miles (commuting and slowly modding).
Zombie Killer
Feb 9, 2020 08:10 PM
Lukas0120
Apr 30, 2017 08:51 PM
trinydex
35
Sep 6, 2015 08:11 AM
David Buschur
18
Mar 17, 2012 10:32 PM
Swashbuckler
Sep 23, 2007 06:16 PM
