care to comment on my spark plugs
Old May 25, 2010 | 02:46 PM
jeangtd's Avatar
Thank's
Attached Thumbnails care to comment on my spark plugs-dsc07305.jpg   care to comment on my spark plugs-dsc07304.jpg
Old May 25, 2010 | 02:49 PM
criptballer's Avatar
you should check this great article found in enginebasics.com
Old May 25, 2010 | 02:51 PM
jeangtd's Avatar
great read, thank's
Old May 25, 2010 | 07:20 PM
UT_EvoX's Avatar
Little rich or a little oil burning, nothing abnormal for a turbo car. Combustion looks balanced among all 4 cylinders. Can't see any closed gaps or erosion, so I'd assume you're not experiencing much if any detonation.
Old May 25, 2010 | 07:30 PM
cij911's Avatar
100% fine....Are you still on the stock tune ? My guess is you are running slightly rich, but nothing too bad....
Old May 25, 2010 | 08:56 PM
did you two read the link i posted? the pictures aren't clear, but if you look at the last plug on the right hand side you can see residues around the base ring, which would be of metal pieces fusing into it from the cylinder walls, which would mean knock. plus we can't even see the heat ring in order to tell how the combustion is doing, i do agree with the little rich fact though.
Old May 25, 2010 | 09:33 PM
XRims's Avatar
Those look very clean compared to mine that I just swapped... serious carbon buildup. I will now say with confidence that on high horsepower evos, they should be changed every 5000-8000 miles.
Old May 25, 2010 | 10:10 PM
jeangtd's Avatar
I am running cobb stage 2 93 octane, i have made logs and have seen little or no knock.
Old May 26, 2010 | 01:19 PM
remember that the AP's knock table reads different than Ecuflash's. meaning, .4 knock on AP could be multiple counts of Knock Sum in ecuflash.
Old May 26, 2010 | 01:48 PM
jeangtd's Avatar
Is there any conversion table for this, max knock count is 1,76 @ 1000rpm on a thrid gear pull on an accestuner log.
Old May 26, 2010 | 02:08 PM
Golden's Avatar
Yes. It is exactly Cobb's CA / .35 = Knock Count.
The AP likes to round to the nearest tenth. So .35 would read .4 on the AP. If you log it, it will be .35 in the logs.
Cobb's CA - Knock Count
0.35 - 1
0.70 - 2
1.05 - 3
1.40 - 4
1.75 - 5
2.10 - 6
2.45 - 7
2.80 - 8
3.15 - 9
3.50 - 10
Old May 26, 2010 | 03:40 PM
jeangtd's Avatar
so 5 knock counts @ 1000rpm and 1 knock count @ between 5800 and 6200 rpm
how bad is that?
