Loud vibration type noise when letting off throttle
I started noticing the same noise with less than 1,200 miles on the car (no mods). Took it to South Coast, pointed out exactly what the sound was, and the tech said it was normal. He sat in the passenger seat while I drove.
Something about the car being very electronically driven and something compensating for the decel once you let off the gas. If you drive on the freeway and practically hover (not literally, but just enough pressure for the electronics / ecu / whatever to know that your foot is on the gas) your foot over the gas pedal while you're decelerating, the noise goes away. As soon as you put your foot off the gas, even if there is virtually no change in your deceleration, the noise comes back. Put it in neutral and the sound is also gone. So I'm going to take the tech's assessment and not lose any sleep over it.
i agree....like i said my old wrx did it from the beginning also. AWD cars are noisy.
I have that noise too, last time i check with my local shop, and we found out the sound is from the drive shaft, and now i went to the dealership, they said it's my whole transfer case, so now im still waiting for my car update and stuff, hopefully they will cover it in my warranty.
Im having this same exact problem. it just started occuring today. Only in 4th and 5th gear right now when i let off the gas and the car starts to like kick back and forth making a weird chattering sound...Any Input ?
Sorry to bump this thread from the dead but was there ever any solution to this or more information regarding where it came from? My T-case is fine and as everyone else has mentioned the vibration/chattering only occurs when I'm off the throttle.
I've had customers complain about vibration from straight through test pipes that don't have a bend incorporated into the design.
You may also have a loose exhaust shield rattling. Can you tell if the sound is underneath the vehicle?
Good luck man, hope you figure it out.
Michael
Michael
Michael
Michael
On another note im also hearing the exact same things as the OP is, described perfectly. Im pretty sure it is not normal though in my case. Sounds like more of a loud grinding, mostly over 3k rpm. And even louder going downhill foot off the gas in gear coasting. Any help would be awesome. All drivetrain fluids recently changed too.
*Just realized this was in the evo X section, oh well, happens in my evo 8 haha*
Thats interesting you say that, i just had my resonator cut out from an aftermarket exhaust and a straight pipe welded in its place by a very reputable evo shop who i will not name, but after that i started noticing a vibration and a loud metal on metal vibrating noise whenever i make turns, but its seems like it only does it at night when its cooler out, when its warm i dont hear or feel anything!! I guess i should start out by double checking heat shields.
Sorry for bumping this old thread but i've been suffering from this too and most likely to make noise in mine when the weather is cold.. And its getting my attention cause winter is fast approaching here in canada.. Btw, i drive IV but then im experiencing the same situation as what u guys described.. Have anyone found any answer for this? It feels like its somewhere in my driveshaft but not positive about it..
millsyy17
34
Jun 6, 2010 09:11 PM
deegaw11
13
Feb 27, 2007 12:20 PM
